Home > Help Needed / General Tech Chat > valve springs
Hi, as a number or peeps here seem to regard the sodium exhaust valves as non essential on a lower power turbo motors. I am going to use a std 1275 head with 35 mm inlets in conjunction with a n/a mg metro cam for my turbo build.
What valve springs should I use with this cam? I will be revving to no more than 6400 ish, with 8 ish psi of boost. Is there anything else I should take into consideration?
Thanks.
prob 180 lb mini spares ones .
It's common to make the valve to guide clearance a bit bigger than standard on the exhausts, to reduce the chance of them binding.
Ask Benross for guidance.
The Minispares ones seem to be a good choice, 180lb will be fine for your application. Guides need to be reamed with a 9/32 reamer after fitting.
i agree minispares 180 pound Double springs part number 526 springs ask jim at minispares north
the pressure is 238 pound on the nose
springs are capable up to 8000 rpm
Thanks, thats that cleared up:)
