Home > General Chat > Water Jet cutting
There is a guy on another forum I use, who runs a company with a Water Jet machine.
Can cut any material, up to a whopping 200mm thick !!!!!!!!
Although obviously the cut isnt perfect at this. He is based in the southwest of England.
Quoting him from another forum.
a couple examples of waterjet cutting, first one was a cable-hydrolic clutch convertion, and you can see 100mm stainless steel offcuts being used a weights to hold it still.
and also my old 1400 cylinderhead i cut in half, and my current bottom suspension mounts from 6mm stainless
Ralph
Just in case this might be a service of interest to anyone :)
If anyone needs, I can link him this thread, or pass on details. He seems to be a car nut too, so hopefully will go easy on people :)
wow i love to watch these cutters at work, looks like a handy fella to know of Steve.
where abouts in the southwest is he? looks like a good service to have a note of.
I'm lucky, I have a place which does water jet cutting, another which does cnc machining and two places which do laser cutting all walking distance from home.
Hedgemonkey
Member #: 360
I know Ralph from the mine exploring bunch I hang out with. He's based in the W of Cornwall. Sort of Redruth area. If I remember rightly, he has a metro with a silly engine. Good bloke, but get your orders in quick as he is probably going to kill himself abseiling down huge mineshafts on suspect equipment. I can vouch for him being up to hear from you. When I see him, I'll get him to register and post.
Stu (mini still in shed)
Hum, that second picture gives me an idea:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=188737
This guys name is Ralph....he his a newbie over on the V8Forum.
He seems to be on a mad notion of fitting a Rover V8, to a PG1 ( Rover ) fwd gearbox !!!!!
Not quite sure what his plans are !
Sounds like it could be the same guy.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
In the early 90's, there used to be a bell housing kit so you could fit the renault box. think it was the 25 V6 one.
Never seen water cutting. Must be cheaper than lasering.
On 19th Jan, 2010 wil_h said:
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Rover V8 can be adapted for a princess box too aparently.
http://www.geocities.com/jharkola/Viku2.html
On 7th Nov, 2008 Nic said:
naeJ
m
jimmy
Member #: 829
essex
That handy saves on the hard work
1293 Turbo mini
