Home > Ebay items For Sale > Race engine and other parts
apollo996
Member #: 1240
Worcester
http://search.ebay.co.uk/_W0QQsassZapollo996
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Is that a grey diaphram with the flywheel?
On 7th Nov, 2008 Nic said:
naeJ
m
How many teeth on the flywheel?
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Another Plenum victim! Pendulum!!!!!!! lmao
Good job I spotted it before Vegard *wink*
Edited by Jason G on 21st Mar, 2008.
On 19th Jan, 2010 wil_h said:
apollo996
Member #: 1240
Worcester
yes its a grey diaphram. Will check on the flywheel teeth number.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Where did you get the flywheel from? Got the same.
Similar weight to the MED one, approx' 3.5kgs.
That head doesn't look like it's had much work.
Edited by theoneeyedlizard on 21st Mar, 2008.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
107 unless I counted wrong. :)
Excellent, they are either 107 (inertia type) or 129 (pre engaged).
I'm after a 107
apollo996
Member #: 1240
Worcester
Regarding the head you are limited on what you are allowed to do in terms of regs. The ports look well enlarged to me and I doubt you can take much more out of it.
apollo996
Member #: 1240
Worcester
Hello Milamber, don't know where the flywheel came from. Was with my class C car I bought last year. R U racing this year?
Edited by apollo996 on 21st Mar, 2008.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
With the regs, I'm sure you can do what you like as long as you retain the inlet manifold rings, compression ratio & standard valves. Valve material seems to be abit of a grey area. I'd like to race this year, only need gaskets & oil and I'm up 'n' running. Need a job first :(
