Home > Help Needed / General Tech Chat > dump valve/Servo pipe
mg-metro-matt
Member #: 1870
Aldershot (we are top of the league, say we are...)
Hi all
Hope you are all having a good long weekend.
Just a quick question, i have ordered a modified carb spacer to plumb the dump valve actuator into, but i cant really be bothered to remove the carb again if its not necessary, so is it ok to plumb the dump valve into the servo pipe?
comes out the inlet manifold here:
Would it be ok to 'T' it into the rubber hose going to the servo:
Or would it be better to fit the modified carb spacer?
Thanks all!
Edited by mg-metro-matt on 22nd Mar, 2008.
yes
mg-metro-matt
Member #: 1870
On 22nd Mar, 2008 BENROSS said:
yes
yes to 'T' ing it into the servo pipe or better to fit modded spacer?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
ive always used the servo pipe, involves less gaskets to go wrong and more carb clearance with the bulkhead too.
mg-metro-matt
Member #: 1870
i shall use that servo pipe then, was just curious as according to the haynes book of lies it has a one way valve or something coming out of the inlet manifold, so wanted to make sure that wouldnt effect the dump valve. I have only just had the carb off so really didnt fancy taking off again if its not necessary.
cheers for the info
Mine is tapped into the to of the servo pipe banjo.
mg-metro-matt
Member #: 1870
does yours not have that one way valve bolted in there which goes off to the air filter?
Nope
metroturbo
Member #: 989
North Yorkshire
I drilled a hole in the side of the servo pipe banjo and brazed in a bit of stainless pipe to connect the dump valve hose to.
As long as you are the manifold side of the vale it'll make no difference.
mg-metro-matt
Member #: 1870
cheers guys, i have a t'piece that came in the fitting kit which is the size of the servo pipe, but if i get keen ile just pull the carb off and use the modded spacer. Started fitting that maniflow system earlier "metro turbo" you have to modify the downpipe to turbo clamp slightly by grinding down the edges of the clamp as it is to small for the bigger pipe, but fits ok after that. Tightening the elbow to downpipe clamp on the drive in the snow wasnt overly pleasant mind!
