| Home > 998cc > 998 Turbo basic spec | |||||||
![]() 514 Posts Member #: 2169 Post Whore Malta (Ex. Scotland) |
27th Mar, 2008 at 09:59:31pm
Finally decided to put my fire breathing Turbo Mini build on the back burner for now and build myself a turbo daily driver.
Warning:Stig in Training
28th Mar, 2008 at 11:08:21am
Well the spec of my 998 road engine will get you very close to what you want.
28th Mar, 2008 at 12:51:36pm
Worth noting that Wil has a 12G295 head. You could use the 12G940, but it is extra hassel getting the block pocketed. http://www.twin-turbo.co.uk
28th Mar, 2008 at 04:24:01pm
Thanks lads.
28th Mar, 2008 at 04:34:56pm
It all comes down to what you have or can get your hands on. If you have a 940 then use it. In standard MG form we had 140 bananas in the TT. It will work fine on the road. Yes you can do what Keith did instead of pocketing, I prefer pocketing though. If this is a daily drive though and low boost it will be fine I guess.
28th Mar, 2008 at 05:59:40pm
Why do you prefer pocketing? Doesn't it ruin the exhaust flow?I know this is just a road engine but I'm curious Warning:Stig in Training
1425 Posts Member #: 690 Post Whore Norfolk |
28th Mar, 2008 at 06:15:20pm
I think as long as you keep the pockets as far clear of the top ring as possible is the most sensible - and make sure there are no sharp edges to the pocket, in the bottom or on the edges into the cylinder/ around the top of the cut out head gasket side.
If Carling made Mini engines
28th Mar, 2008 at 06:16:08pm
2.750" rings a bell for some reason but not 100%.
28th Mar, 2008 at 06:22:18pm
this one measures 2.665"? If Carling made Mini engines
28th Mar, 2008 at 06:58:52pm
John, not sure about the unskimmed thickness, but they should be 28cc chambers iirc. http://www.twin-turbo.co.uk
28th Mar, 2008 at 07:57:46pm
unskimmed they should be 2.750", but i dont think its a hard and fast rule "Turbo's make torque, and torque makes fun"
29th Mar, 2008 at 12:34:15pm
Right so far it's a 9:1 CR,940 head,CT9 Turbo on mirage manifolds,Pocketed block.
Edited by El Potter on 29th Mar, 2008. Warning:Stig in Training
29th Mar, 2008 at 12:50:33pm
The 940 chambers are smaller than the 998 ones.
29th Mar, 2008 at 01:07:31pm
Smaller? wow I never knew that.
29th Mar, 2008 at 01:08:27pm
You'll need to do some volume measuring, no good guessing. Remember to include any pocket volume in the calcs.
29th Mar, 2008 at 05:00:17pm
Righto Tom.
4 Posts Member #: 2853 Junior Member Canberra Australia |
15th Jun, 2008 at 01:23:18pm
Try the 12G202 heads from the 1100 and some of the rileys I think. I have mine on a warm 998 with a 0.030 overbore. The big thing with these heads is de-beaking them and making sure you have the chamber size doent blow out in the overall equation(I have 9:1 for my set-up).
Rob Forsyth
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
15th Jun, 2008 at 05:48:02pm
can you open up a standard 998 head big enough to make it worth using or is it just not worth it? |
15th Jun, 2008 at 08:41:02pm
Too much trouble looking for one of those heads Rob.
21st Jun, 2008 at 08:10:35pm
Standard 998 cam will be good for your purpose Fastest 998 mini in the world? 13.05 1/4 mile 106mph
22nd Jun, 2008 at 09:16:51am
Ok Wil. Thanks mate. Warning:Stig in Training
14th Oct, 2008 at 11:18:13am
Yepp there are many ways to skin a cat Potts. I use the 202 here as they are plentiful and you dont have to do too much to them to make them work well - loads easier than pocketing the block for a 1300 head and the likes.
Rob Forsyth
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
17th Oct, 2008 at 10:11:50pm
On 28th Mar, 2008 johnK said:
I think as long as you keep the pockets as far clear of the top ring as possible is the most sensible - and make sure there are no sharp edges to the pocket, in the bottom or on the edges into the cylinder/ around the top of the cut out head gasket side. I have a 295 under the bench - anyone know the before skimming thickness? This has got me curious, by sharp edges doe this mean that dead square edges are a no no, should they be radiused? If so, why? Think the ones in my 998 was square? Cheers Shane |
998 Cooper.Oh.
