Home > Help Needed / General Tech Chat > Final Drive Pinion Nut
apollo996
Member #: 1240
Worcester
How do people get this tightened upto the required torque setting? When I try the gearbox rocks about all over the place.
i lowered my car wheel (not all the weight) onto the box to keep it still
just not using a volvo.....
I installed two anchor bolts into the garage floor and bolt the box to them. Carefull which way round you bolt the box when tightening and loosening *wink*
Scruffy
Member #: 328
Seaford Rise, South Australia
Use a couple of g clamps to workbench or even workmate as you can stand on it as you tighten it!
On 5th Sep, 2011 Vegard said:
be careful if you anchor it to a bench...
I had mine securely attached to the bench when something went, catapulting the bugger across the garage, cracking the casing. luckily I was trying to take apart a knackered box, so no great loss.
johnK
Member #: 690
Norfolk
I used to use the sill of a car - but the 4 post is much easier to raise/lower!
If Carling made Mini engines
I use my dad! Any better?
I found the wife to be too ikle
i stand on the casing, and then use my big torque wrench
If it ever slips i think i would actually die
clubman_dan
Member #: 142
Winchester
to get the 1st motion shaft nut off/torque it up i had to put the gearbox under the car, i used my new impact wrench to get the pinion nut off though.... no worries!
i tried standing on the casing but, i did nearly die a couple of times lol, almost headbutted the garage wall!
