Home > Wanted > Remote oil take off
I started to fit the MPI rad to the BOC this morning only to find it fouls on the remote oil take off:
does anyone have or know where I can get a take off that comes out the top instead of out the front like this one:
Rob
How much room do you need to save? A banjo fitting there would surely gain you some room?
Nice one Tom, I never thought of a banjo bolt but that would work a treat.
Edit: Would a banjo fitting flow enough oil?
Double edit: Just realised that the stock Rover set up used a banjo bolt.
Edited by Rob H on 25th Apr, 2008.
sorry about not getting this sorted yet rob, had a million things on.
Ill try my best to have one to you by the end of the week
joe
I alway though banjos were quite restrictive.*oh well*
Ive got one of Joes take offs, saves loads of room!
Joe,
If you could sort me out with one that would be great, the plan is to have the BOC back on the road by the end of the month.
Ill get on it!
the pump would overcome any ... slight restriction with the banjo fitting
go for it
