Home > Help Needed / General Tech Chat > R5 GTT carb, any good?
Saint
Member #: 1909
Cracow, PL
Hi there,
I've been wondering if the R5 Turbo carb will be any good for mini? It's harder and harder to get the metty turbo thing (especially here in PL), so i thought it's worth asking.
What are other options? pressurized dellorto from Lotus or suck-through setup?
Oh, yeah, i forgot. I would get into 998 A+ probably with Bini SC, 5-7 psi boost to start with.
Cheers, Roman
If you're planning on a suck through system then you can use any carb you want, it doesn't need to be able to cope with pressure.
If using a blow through, then the GT carb I'm sure could be made to work fine.
Saint
Member #: 1909
Cracow, PL
blow through would be better option. I can use intercooler and some sort of dump valve/blow-off valve, which i couldn't with suck-through. Unless one like to have mist of exploding gases in engine bay.
Anyway suck-through is last option i was considering with forced-induction.
Thanks for the reply
The R5GT carb is at best, troublesome as i recall from the time when folks used to tune them. The SU is simplicity at its best y comarison.
But if all you can get is a R5GT unit....
If you can't get a Metty Turbo Carb, it's very easy to convert a standard HIFF 44 carb. Just another option.
Star Mag
Member #: 375
Leicestershire
People have figured out how to tune the 5 carb now rather than just wackin a dirty big main jet its a case of playing with the enrichment jets! However i would be converting a standard metro carb, it would be easier!
Saint
Member #: 1909
Cracow, PL
Hmmm... so with hiff 44 it's only a matter of getting service kit and some minor machining. Think i'll give it a try. Unless i get the real thing meantime.
Thanks
If you need a HIF44 Turbo carb rebuild kit, let me know i still have some left.
