Home > General Chat > Cheap milling machine
Now ideally i want to get myself a bridgeport but i was wondering if anyone had used on of these:
http://www.machinemart.co.uk/shop/product/...thes-milldrills
i want a drill press so thought for about £75 extra i could get this? Its only to make brackets and things, mill odd flats etc. certainly no precision stuff.
i've got a colchester triumph lathe, and as i say, at some point will buy a birdgeport but i thought this might be neat?
Machinemart have a VAT free day thursday night so thats a good chunk off, comes out at £219
we have on of the clarke lathes with the milliing bit on, its pretty shite.
They don't look rigid enough TBH.
Me too, it's the bigger "better" blue one rather than the yellow one from their catalogue.
and as a small cheap lathe, it's just about OK, but for milling... Hmmmmm.
The yellow one you're looking at is just a drill to me.
Edited by Rod S on 21st Apr, 2008.
yep,
thats the puppy, as you say the lathe is ok, especially if you adust all the backlash out, but the mill is crap, we had to mod ours to get it any wher near usable.
Leonard
Member #: 806
Cirencester, Gloucestershire
i have a blue clarke lathe, and it's fine when it's all set up. I use a vertical slide on it for milling.
yep,
How do you adjust the backlash on the cross slide?
My Chester is OK, but the cross slide has a lot of backlash making heavy cuts tricky.
The Chinese tanslated manual gives no clues.
Leonard
Member #: 806
paul, some of them have a threaded boss that's in 2 halves. clamping them up harder brings some of the threads closer together
Thanks, I'll have a look.
to be honest i thought as much!
oh well, just stick the money towards a bridgeport then i guess. luckily i have 3 phase in my dads workshop
yep on the clark under the movable bed there is a bronse/brass threaded thing that has a slit in it so you can take up the slack,
also there are allen head screws in the side with shims that can be adjusted.
also where the handles/wheels are mounted there are screws that hold the bearings in place, these can work loose giving extra movement.
Its all basic stuff, just pull it apart and you'll naturally reassemble it properly.
Yes, had a look.
Seems I have to release the end of the cross slide screw and then unwind the cross slide right out to get at the threaded part.
Apologies for thread jacking.
Looks like I need to adjust mine then as well.....
Apart from thread jacking, the Clarke stuff is very basic - Chinese (really) so takes a bit of getting used to and "improving" where you want, but is well over-advertised for what they say it can do...
Andymini
Member #: 438
London
I purchased a secondhand Dore Westbury mill a few months ago for £100. These are a bit bigger than the mill you have pictured, which is a Sieg X1- they sell them under a variety of different brands, Chester, Warco, Axminster etc.
The Dore Westbury was a kit of machined castings supplied in the 60's and 70's for model engineers to build a small workshop mill with the aid of a Myford ML7. It's a nice little mill for the money, and better than the chinese imports. The latter effectively killed off the Dore Westbury, as the castings cost more than a complete machine from China.
I'm converting it to cnc. The machine had a bit of wear in the slides and some backlash in the Acme threaded screws.
CNC requires zero backlash to be effective, but I didn't fancy forking out for ground ballscrews, so needed a cheap alternative.
I have moulded some plastic lead nuts using offcuts of water board mains pipe (the blue stuff). The plastic is very low melting point, and goes like wax when you apply a paint stripper heat gun. I pushed this around the thread with a wooden mould- the result is a formed in place thread which is a perfect mould of the thread. - this has removed all the backlash in the screws, and the thread is smooth in action.
I also fitted acetal gib strips on the slides which reduces friction, and takes up any slight wear.
Andy
Edited by Andymini on 21st Apr, 2008.
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
You can get single phase bridgeports you know iain. Im sure ours is. Plugs into the wall anyway.
If i were you, Id get a bridgeport over one of those clarke ones.
yeah but i have 3 phase so you find they are usually cheaper.
these are cheap i think ian .
Iain,
I've not used one of them but I'd question how good it would be as a drill press with only a 150 watt motor, for comparison my drill pres has a 1.5 Kw motor.
Jordan
Member #: 1392
If a 3 phase bridgeport comes up, do you want me to let you know?
not at the minute mate, unless its really cheap (£500ish) as i'm moving house so i'm skint!
n.g.l.
Member #: 181
Chard, Somerset
This might interset you Iain,
http://cgi.ebay.co.uk/SINGLE-PHASE-PALLAS-...1QQcmdZViewItem
good spot *smiley*
its located in lincoln where i'm just moving too as well!
