Home > Help Needed / General Tech Chat > Spark Plugs
Zeemax Power
Member #: 393
Oulton Park
brought some plugs NGK 6464 BPR6E mini sport said they would be fine is this true. Look a bit longer the plug wont it the pistons. Scared put them in lol.
http://www.Zeemax.com
Ric
Member #: 36
Basingstoke
is it a turbo or an na engine.
Assuming its a turbo, i'd say 6s were a little warm. I use (and so do a fair few people on here) NGK BPR7ES plugs
I used the BP6ET's for about 2 years and they were fine, I then switched to the BPR7ES when I up'd the boost and changed to MJ.
7's would probably be better.
Ric
Member #: 36
Basingstoke
have just seen the other thread about running 15psi, yeah, 6s really aren't what you need. In the summer you may even want to go to 8s.
Do a search, there is a shitload of info on this, it really helped me when i was having plug issues.
