| Home > Help Needed / General Tech Chat > Laygear needle bearing | |||||||
86 Posts Member #: 1240 Advanced Member Worcester |
27th Apr, 2008 at 07:58:29pm
I have 99% of the parts for a challenge spec sc gearbox I plan to build. It doesn't use the standard needle bearing on one side (the smaller gear end away from the drop gears) as the std type is too small in diameter. Does anybody know what bearing the laygear takes and where I can get one? Any help would be appreciated. |
27th Apr, 2008 at 08:02:04pm
I'm confused as to which bearing you mean? A pic of which one would help here.
27th Apr, 2008 at 08:09:00pm
The needle bearing. The laygear takes 2 (1 each end) to enable it to rotate on the layshaft. On my laygear the hole for the needle bearing nearest the reverse gear area is too big for the std bearing. |
28th Apr, 2008 at 10:13:00am
sounds like ?? you may have a jack knight set, Richi on here came across the same problem Please PM him and ask him where he go hold of his
Edited by BENROSS on 28th Apr, 2008.
28th Apr, 2008 at 10:15:03am
As above I seem to recall the JK ones being specific and only available from JK.
28th Apr, 2008 at 11:10:28am
I can't find a Richi listed to
28th Apr, 2008 at 11:41:32am
Try "Richie"
