Home > General Chat > 3 DAYS TO GO AND COUNTING!
shane
Member #: 1246
Lowestoft, Suffolk.
Then its off to T&M for a session on the rollers, and Im slightly nervous!
Shane
Dont worry, Uncle Ray will take good care of you.
turbo hogster
Member #: 178
stowmaket suffolk
good luck shane may the force ( sorry boost) be with you
wd5k
Member #: 2543
Ipswich!
good luck,....
ben to T&Ms a few times... not had any of my cars rolled there.. but mine will be going there!..
keep us posted
jamz
Member #: 2292
Tool
Herne Bay, kent
this is wehre mine is going i think... need to book it!
cant beat a good blowout.
shane
Member #: 1246
Lowestoft, Suffolk.
Well it was an eventfull day yesterday, lost a mud guard off the trailer on the way which took a swipe at the mini door on route and the sat nav thru a fit an took me down a dead end lane which I had fun and games trying to back up of, anyway, the rolllers.
Ray at T&M Is a absolute legend and really nice bloke, one of the only places I have taken the mini that let you join in with what he is doing, telling you what he is doing and why, very accomedating (SP) The first thing he done was polish the needle to get the fueiling right, he then spent a few runs mapping the MJ all was going well untill we tryed to opperate and set my boost control, Iwas planning 6psi on the actuator and 10/12 psi bled off a bleed valve connected off a solenoid off the mj, but we found the solenoid I used wouldnt flow more than 6psi, BUGGER! So will have to settle for 6psi untill I can source another and get back down to Ray.
The first run made 77bananas at the wheels at a mear 4.5psi boost, at the end of the session we had a hearty 111bananas and 116 curlywurlys, which after spending the afternoon and evening driving the car im pretty happy with for now! Im a little worried about running more boost at the moment as there was a little crap/smoke comming out of the crankcase breathers when you let off the throttle on full boost, concerend the rings wont take it. Also im running a verto clutch will more than likely shit its self before long.
But all in alll its a good start.
Shane
good going for only 6psi
shane
Member #: 1246
Lowestoft, Suffolk.
Its an animal to drive (but have just came from 65bhp 998cc), more power is going to be interesting, and scary!
Shane
jamz
Member #: 2292
Tool
Herne Bay, kent
nice one... when my head is back and all fitted up im going to take it to ray... herd good stuff so...
how much will it cost me for a set up?
shane
Member #: 1246
Lowestoft, Suffolk.
I payed £158.62 for three hours. tought it was reasonable.
Shane
jamz
Member #: 2292
Tool
Herne Bay, kent
yer not bad... hope everything turns out ok on mine :S lol
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Great value there! Top result shane.
You got a bigger pic so I can check out the calenders on the wall???????????????
Shane
Edited by Jason G on 7th May, 2008.
On 19th Jan, 2010 wil_h said:
shane
Member #: 1246
Lowestoft, Suffolk.
Nope but believe me, definatly worth the look, was stood next to Ray at his bench and found it hard to concentrate LMAO!
Shane
turbo hogster
Member #: 178
stowmaket suffolk
yep he is a top bloke and only charge £40 an hour plus the vat.
you wont get better than that.
still great result for 6psi.
what engine is it, is it an old one or a newbie you have built.
but like you say those verto's aint realy upto serious turbo torque and power, best to change to pre verto with a grey diaphram and ralley plate.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Not seen a dyno that old in years *happy*
AlexF
shane
Member #: 1246
Lowestoft, Suffolk.
Engine spec is as follows
1275cc bottom end (aprox 70k)
Centre mains strap
Avonbar phase 2 cam
Benross spec head, 8.4:1 CR
Std inlet and Turbo carb, with polished needle
Custom plenum
Escort RS IC
R5GT T2 on mirage manifold
Playmini 2" exhaust
Nothing extravagant but its a start
A new clutch is on the agender but time is a bit short at the mo.
Shane
i was planning to use a benross head, +20 or +40 block, centre main strap, ps2 cam, megajolt, mega pistons, fmic and about 12psi of boost, i wanted about 120hp.... i may have to downgrade the boost or somthing lol
shane
Member #: 1246
Lowestoft, Suffolk.
That setup and possibly 8-10 psi should give you what your after? based on mine being 111bhp @6psi?
Shane
turbo hogster
Member #: 178
stowmaket suffolk
depending on CR its approx 5.5bhp to 1 psi increase
jamz
Member #: 2292
Tool
Herne Bay, kent
im guesing that all these figures are at the wheels ???
Snakeii
your looking at well over that figure
a guess with the elbow mod and exhaust manifold with a good intercooler 155+.........BHP
