Home > Help Needed / General Tech Chat > Question for supercharging
Giancooper
Member #: 2402
Hi guys I'm from italy, but I left 1 year in London,I love it... and the mini.(sorry for my engish)In this forum I saw a very "big" mini and great good job...
Now my project is..
An eaton m45 on front of the engine whit a blow-through system whit an intercooler...
How many psi I can run whit my n/a engine trasformed to supercharged whit 8.2 cr?
I modify an a N/A hiff 44 to turbo one, I put the seals on the dashpot and change the needle... after? what I need to change?
I need same help from Italy
Edited by Giancooper on 3rd May, 2008.
With that CR and an IC, you could in theory run 20psi with everything set up well.
However the M45 is pretty inefficient after 10psi, so you'd be wasting your time,.
Giancooper
Member #: 2402
Thanks, so I'm going to 10 psi, and for the hiff 44?
What I need to change after the seals on the dashpot and the needle?
The other crucial part of the turbo carb is the plenum. This has a restrictor ring in to ensure that the floatbowl pressure is above the charge pressure.
Giancooper
Member #: 2402
I have the metro turbo plenum....
But I don't now if the needel valve or other component of the carb are the same...
The carb is identical other than the seals as far as I know
