| Home > Technical Chat > Dry deck & cooling | |||||||
5th May, 2008 at 08:34:36pm
I know some of you are dry decking your engines. I wondered if you would be kind enough to tell me the reason you are doing this.
Edited by danboy on 9th May, 2008. |
5th May, 2008 at 08:46:07pm
Dave, you need to block off any water passages from both the head and block,, this prevents any water getting to the gasket or cylinder preasure reaching the water system.
5th May, 2008 at 08:57:14pm
hi carl
5th May, 2008 at 09:00:46pm
yes been there done it , now have it fully dry decked, so no water way preasurisation if HG fails,, down side is there are little clues if the HG does go, you have to start looking for leaks.
Edited by fastcarl on 5th May, 2008. |
5th May, 2008 at 10:04:37pm
Makes a lot of s ense.
5th May, 2008 at 10:36:07pm
On 5th May, 2008 danboy said:
Makes a lot of s ense. How do you control the cooling of the block and head as they are both seperate after dry decking? Are you useing electric water pumps? Dave fook ,i'd not thought of that, prob why the heads gets stinking hot, lol, ONLY KIDDING, external link from head to block on clutch end , and a leccy pump, but if you'd, poped along to york raceway more oftern last year you would have known all this already.lol. carl |
![]() 646 Posts Member #: 1826 Post Whore Maldon Essex |
6th May, 2008 at 05:59:06pm
what size bore silicon hose do people reccomend for this?
6th May, 2008 at 06:04:53pm
I think most installs have an inch hose. On 28th Aug, 2011 Kean said:
6th May, 2008 at 08:07:53pm
7th May, 2008 at 10:54:44am
http://s24.photobucket.com/albums/c2/carl1...ydeckdetail.jpg
7th May, 2008 at 11:13:15am
Swift tune sell this for the less adventurous.
7th May, 2008 at 11:40:29am
£76 .00 inc vat and postage, fook that,
7th May, 2008 at 11:46:32am
There ya go. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
7th May, 2008 at 04:23:28pm
On 7th May, 2008 fastcarl said:
£76 .00 inc vat and postage, fook that, dont anyone buy one, i'll do it cheaper, Carl can you turn me up some similar adapters and I'll pay cash. Two the same with 32mm stubs, and no fixing holes as im not sure how many or where im going to position them. How much? I was going to buy that Swiftune kit, but seeing as you have offered :)
Thanks in advance :) Sprox On 26th Oct, 2004 TurboDave16v said:
8th May, 2008 at 06:01:44pm
yeah id be interested in a pair aswell, 1 with the fixing holes as switunes and 1 with out the fixing holes.
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
8th May, 2008 at 08:51:18pm
i have heard this before on another forum yrs ago but cant remember the response so i'll ask here.
Edited by Simon on 8th May, 2008. |
8th May, 2008 at 09:02:56pm
not really ,unlerss you block off either the head or block waterways, if you dont it will still try to thermo syphon, by blocking off the waterways you will force the water along the block and up into to head through ths link pipe, how effective using a normal pump is debatable , but i have used this very method on my twinnie for years.
8th May, 2008 at 10:33:04pm
What do you mean, dry decking and a mechanical pump? Why shouldn't that work? On 13th Jul, 2012 Ben H said:
8th May, 2008 at 10:52:33pm
because a mech pump is not the most efficient, electric pumps are a lot better surely, |
1391 Posts Member #: 1686 Post Whore Oxford |
12th May, 2008 at 01:47:04pm
id feel better off useing a mech one. electrical ones tend to go wrong i feel. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
12th May, 2008 at 03:02:43pm
All depends how hot your engine get and what you use your car for, a mechanical pump would have no chance keeping my engine cool Team www.sheepspeed.com Racing
12th May, 2008 at 03:27:29pm
On 12th May, 2008 Sam said:
id feel better off useing a mech one. electrical ones tend to go wrong i feel. On 28th Aug, 2011 Kean said:
12th May, 2008 at 05:53:05pm
would the better flowing one not cavitate (gone blank and cant seem to think of the proper word but that sounds sort of close in my head :S ) off of the worse one? |
12th May, 2008 at 07:15:34pm
What head gaskets are available with blocked waterways? Might give it ago.
On 19th Jan, 2010 wil_h said:
12th May, 2008 at 07:52:52pm
