Home > General Chat > What garage vehicle lift to buy
MrTurbo
Member #: 814
Utrecht, The Netherlands
Just a short question:
whats the most usefull for working on a Mini, a two post or four post vehicle lift?
thanks
Edited by MrTurbo on 8th May, 2008.
evolotion
Member #: 83
Glasgow, Scotland
2 post wind every time for me. easier access to the suspension, more compact, allow biggerjobs liek subframe removal to be carried out wiht ease as there is no obstructions. and less things to hit your head off.
4 post has only 2 benefits, somewher to put your tools and makes suspension geometry changes a snap as you can do allignment under the car while all its weight is on the wheels.
some people dont like 2 posts as they look flimsy and unstable. but the really are great to work with. imho.
Denis O'Brien.
G13B
Member #: 1376
Have you considered a lifting table ?
Scissor type, neat and cheap *Yes*
//marcus
i use two post lifts at work and you can lift transit sized vans on them without any trouble apart from how wide they are *tongue*, it was a doddle to use for the mini as the weigh nothing :) easy to work on and you can take the subframes in and out engines ect easaly with one
stefaz
Member #: 1656
stoke-on-trent
hmmmm :( looks out at mini on the drive. have worked with 2 post lifts - never really thought about it when i was working underneath them, but they allow much more access for things like subframes than a four post imo
