Home > Help Needed / General Tech Chat > couple of gt17 questions
When mounted to the metro manifold with an adaptor plate, do they protrude as far back into the bulkhead as the t3? could you get away with a smaller bulkhead box?
Second question is what sort of rpm to they boost from and what sort of rpm does the power start to drop at the top end?
Thanks
Considering I have a GT17 on a metro manifold you think I'd know the answers, but I dont.
The main problem is fitting an actuator though, so my box is actually bigger.
Boost threshold, is higher than a T2 (R5 type) and lower than the metro T3. It's not in the middle though, it's closer to the T2. My power is still on the up at over 7k, but that's a 998. It'll flow enough air for over 250bhp.
