Home > General Chat > Off Topic, Ford focus Wheel bearing
I think there are a few of you here who work, or have worked for fords, maybe you can help me out.
How long does it take to change a front wheel bearing on a 2002 Ford Focus? Do I need a press, is it simple on these?
3 days....
cheers mate, is that pissed, what about if I havent't had a drink
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
IIRC its a press only job...
ring up a dealer and ask is probably the best way, or I can try and have a look tonight,
alex
AlexF
dan
Member #: 93
my old man took his in to be changed, we did do the back bearings at home, but they took 2hrs!!
you'll definitely need a press, maybe even a gas torch to help pop off the inner bearing if it gets stuck and seperates
good luck!
yeah it is, wasnt very helpful but thought i had to chip in some contribution!
I was looking at the "worse case" *smiley*
Thanks for you contribution iain, don't know what I do without you,
Bollox, thought I could do it myself, more cash I've got to spend
Edited by Jimster on 26th Jul, 2004.
Ben H
Member #: 184
Melton Mowbray, Pie Country
When I did my elise wheel bearing, which is a press fit, I removed the hub assembly and stripped it down. then I took it to a local garage who charged me a tenner to press out the old bearing and press in the new one (took about 5 mins). Then bolt it all back together.........
Jobs a good one.
http://www.twin-turbo.co.uk
no worries *happy*
Good idea ben, probably the cheapest and easiest way depending on whether you've got a spare car.
An elise hey, how posh! *smiley*
