Home > General Chat > 10 inch wheels
the shed
Member #: 317
Hello lads
Just wondered what brakes you lot was using under ya 10 inch wheels ?
Read on other web site that some people are using feista calipers when thay want to run 10 inch wheels :tired
thanks darrell
SON, WHATEVER FANCY SHIT YOU'VE GOT UNDER THAT BONNET, SEEN IT A MILLION TIMES
sauber 200
Member #: 245
never heard of that before,maybe someone
else has?
7.5 cooper s are best bet but exspensive,but i think you can modify later set up,
dan
Member #: 93
i've got some adapted metro turbo drive flanges and discs ie. lugs machined off drive flanges, and discs machined down in diameter. With this I am running the minispares alloy 4 pots, still bedding them in at the minute, but they seem good
i think there are a few others on this site that run a similar set-up
cheers!
minimark
Member #: 19
newcastle
yep , no probs minor mods ( grinder) on front edge of caplier.
http://p211.ezboard.com/fminiclassicgenera...icID=6319.topic
I've borrowed some minispares callipers
Turbo Shed
Member #: 30
Epsom, Surrey
i use metro vented discs and calipers. the discs are turned down to 7.5inch and the calipes moved in with the aid of the angle grinder and mig welder.
why you changing to 10's D?
Im just on cooper S gear with vented discs.
Fiesta stuff does look good though, im tempted to get some bits and see how it goes then flog the S stuff.
billydude
Member #: 48
Leicester
the fiesta conversion is easy enough and pretty cheap *wink*
I just can't describe it very well *laughing*
I'm not so sure the front of the caliper needed grinding
as like a twat I fitted the wheel's before hooking up the brake pipe's so the caliper had'nt pulled itself in
*laughing*
Turbo Shed got any pics of your brakes ?
Edited by billydude on 27th Jul, 2004.
Billy, to summarise the list of bits:
Metro driveflanges
mini 8.4" solid discs turned to 7.9"
mk1, 2 or 3 fiesta calliper with bracket.
Hoses to suit although the fiesta has M10 x 1 threads in it
thats about it isnt it?
Make the calliper holes line up and your away?
Ive had a good read just hope i was getting the general jist of things *smiley*
Just need to find some callipers for the back now....
billydude
Member #: 48
Leicester
yup that's it realy
the caliper bolt holes are just about right as getting rid of the threads from the hub's lines the bolt's up
pics can be found at http://www.billydude.50megs.com/photo.html
it's pretty obivoius what need's doing when you have the bit's and start offering it toghether
I did a spare hub before trying it on my car
I am considering a rear disc conversion useing rover rear caliper's that I have already got *wink*
Ah right i see, so the fezzy callipers are threaded and the bolts go into them rather than into the hub like the mini?
Yeah it does all seem to make sense. best get some spare hubs to play with me thinks! Might check out some other callipers too.
billydude
Member #: 48
Leicester
yep the caliper is threaded :)
I'm alway's look at caliper's when I go scrap yard hunting
I'd say there probably is a better caliper for the job as the inner 1cm of disc is untouched by the pad's
but since this was already a tried and tested method with a reasonable amont of info about it I figured it will do me :)
Might have to go for a day to the scrappy, dont really go often enough!
Be nice to find something common that new parts are easily available, wonder what the smart cars use.....
billydude
Member #: 48
Leicester
I would'nt mind seeing what the old honda sooty van's have for front brakes since they run on 10s
I'll have to get off my arse and order some braided hoses soon *blush*
smart cars run 15" wheels, so they not going to be small
for some reason thought they had smaller std wheels. nevermind!
A lot of rear callipers are quite small though....
not sure about std, there was one in the car park at work which had 15's, don't know if this is std or not
ill take a look at some point, walk past one most days!
Yeah just noticed a lot of rear callipers are quite small, reckon i might take a look at something like saxo vts rear callipers. Be good to get some on the back as well. Im going to keep a spare half rear subby to play with.
the shed
Member #: 317
yEA I WANT TO RUN 10S ON THE SHED
tHANKS FOR THE INFO
DARRELL
