| Home > Technical Chat > Trigger wheels | |||||||
15th May, 2008 at 03:11:49pm
I'm helping a friend with his miglia, at the moment he has a trigger wheel with only 3 teeth on it (4-1). As the miglias are not allow to have any form of load sensor, (MAP, MAF or TPS) it's a tottaly flap map with simply rpm sites only. The ECU is about to be replaced, while we are there would benfit at all from having a 36-1 trigger wheel. I know the theory we would, but in reallity, on the dyno would we see any difference? Team www.sheepspeed.com Racing
15th May, 2008 at 04:31:10pm
I'm guessing as I've only used 36-1, but a couple of possible reasons that a 36-1 would be better:
15th May, 2008 at 06:09:26pm
is it 4 notches cut out, or 4 lumps sticking out?
16th May, 2008 at 01:33:49pm
it's 3 lumps sticking out, so it would gain weight if we added 32 more teeth Team www.sheepspeed.com Racing
16th May, 2008 at 06:51:07pm
3 teeth sounds very primitive indeed !!!!
16th May, 2008 at 07:10:12pm
Ign only... On 17th Nov, 2014 Tom Fenton said:
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
18th May, 2008 at 01:28:45pm
the max torque and max bhp advance are mostly quite near and in the powerband (mostly above 4k i reckon) i would not expect the advance needing more than 3-5 degrees change at the most, probably less.
Edited by Sir Yun on 18th May, 2008. That sir, is not rust, it is the progressive mass reduction system
