Home > Technical Chat > Front Brakes When Drag Racing
Something for the Avon Park boys to think about:
Would you be better off running drum brakes on the front? I've not weighed them but I'd have thought that a set up with minifin drums would weight about the same as steel discs and alloy calipers, but thats a side note. The main benefit I can see is that they have a lot less rolling resistance.
Depends if it was a dedicated avon machine or not I suppose?
How about just remove the front discs and calipers altogether?
would the rears not have enough braking.
(not a serious sugestion BTW *wink* )
I've been over the line at 118mph in The DON, if something went wrong and I needed to stop quickly I really wouldn't want drums on the front!!!
The big problem would be the little cv joints
Paul
Paul
wouldn't be a prob in a a straight line , problems occur with plate diffs and the transition from deirt to tarmac when the diffs all wound up,= broken CV's.
been there done that.
carl
