| Home > Technical Chat > compressor surge under full throttle.. | |||||||
18th May, 2008 at 08:24:44pm
I am experiencing something odd. if i load the engien up in 4th or 5th i will get full boost(say .8 bar) by approx 5000 rpm this will hold flat til 6000 rpm, then it will spike to anything between1.3 and 1.5 bar and very quicly settle again to the regulated boost level all the way to the soft cut limiter at 7900.
18th May, 2008 at 09:04:30pm
Surge woul;d do the oposite. Pressure would be seen to drop then rise.
18th May, 2008 at 09:10:50pm
Sounds more like a boost control issue.
18th May, 2008 at 09:33:48pm
sticking wastegate spindle when it gets hot ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
18th May, 2008 at 09:44:41pm
I agree about it being a boost controll issue but i was starting to doubt myself:
19th May, 2008 at 12:25:13am
here she is...
Edited by evolotion on 19th May, 2008. turbo 16v k-series 11.9@118.9 :)
520 Posts Member #: 2093 Post Whore Grenoble, France |
19th May, 2008 at 08:12:40am
How about ignition advance ? Backing-off ignition too much makes the opposite of the expected: it creates after-burning condition (ALS like) and makes the pressure rise. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
19th May, 2008 at 10:12:02am
did you try the waste gate spindle movement with it hot, evo ? is there an internal faliure of the pipe to the wastegate letting it collapse in a sneaky way ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
19th May, 2008 at 10:54:31am
The fact that the boost soon goes back to where it should be would indicate that the wastegate is sticking. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
19th May, 2008 at 06:55:04pm
alpa, the boost rise results in a very pronounced increase in power. i do map my car on teh road rather than the rollers, so i know my timign is quite conservative, i will try throwing in some advance anyway. this cylidner head has given me slightly lower compression ratio than the last one so a re-tune is on the cards, but i wanted to sort this boost issue first. for obvious reasons!
19th May, 2008 at 09:46:39pm
well its sorted... i had the actuator attached to one of those wee handheld pumps instead of my foot pump, so had finer controll over it. noticed it was a bit notchy, didnt notice this before. it would appear that the rod is hitting teh wee hole it passes through. to remove the head i have to remove the turbo, to do that i have to remove the acuator bracket (its very tight down there!) and there is enough slop in the mounting holes so it can be mounted touching or not! cheers for keeping me in that area, always the simple things. Edited by evolotion on 19th May, 2008. turbo 16v k-series 11.9@118.9 :)
