Home > Technical Chat > KKK Twin scroll turbo
This looks interesting:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...ME:B:SS:GB:1123
175 hp, with a twin scroll on the turbine.
Anyone know what that the black box on the compressor housing does?
Edited by Paul S on 21st May, 2008.
A quick search on the web says the black box is an integral dump valve (recirculating, obviously).
Very neat.....
I was thinking dump valve.
who's going to buy one then!
I found the forum post that you are refering to. Not convinced.
Ah yes, I see the shaft now!
indeed must be a stepper or solenoid for the vane.
Edited by Joe C on 21st May, 2008.
The picture is confusing, the shaft is the wastegate rod although in one picture it looks like it comes from the black box.
Quite possible, a lot of the newer turbos with guide vane control on the turbine (instead of a wastegate) use stepper motor control now.
As it's on the compressor, it could be designed to achieve the same as a dump valve (prevent compressor from stalling) and alter compressor characteristics as you say, by opening a gate or moving guide vanes.
Buy it and pull it apart !!!
There is a Press release on Borg Warner's own website that says certain newer versions of the K03 and K04 have integral "blow-off" valves, so I'm back to my first theory, integral dump valve, BUT, possibly operated by the EMS rather than a simple vacuum line, hence the electrical connector....
Boost control on this engine must be complicatted to get 240lbft from 1600 to 5000rpm.
My vote is for variable difuser technology
Edited by Sprocket on 21st May, 2008.
The theory of the twin scroll turbine housing is that you can achieve higher peak gas velocities by seperating out the exhaust pulses.
If we fed one tract from the middle exhaust port and the other from the outer ports, then the peak nozzle velocity would be twice as high. This would bring boost in lower down.
Yes, but you need to control it more at the higher RPMs, otherwise boost would run away.
Variable diffusers change the compressor characteristics, much like the variable vane change the turbine characteristics
We use variable diffusers on our larger machines so they can operate at lower capacities. They work in a manor that literaly changes the flow capacity of the compressor wheel, almost as if the wheel was smaller itself.
evolotion
Member #: 83
Glasgow, Scotland
black box is the dump valve, its electroniclally operated. iv fitted a few blanking kits/ kits to converto them so they dump externally.
Denis O'Brien.
Variable diffuser:
http://www.turblexinc.com/getTechDoc.cfm?d...t=PDF&task=view
A quick trawl of the net shows that the OEMs are looking into this.
However, until they become mainstream we are not going to be using them.
You could use a twin scroll turbine with a diverter valve that would send all the exhaust gas through a single scroll at low flows and then through both scrolls as the flow increased. This would increase the nozzle velocity and wheel speed which would bring boost in early. Probably easier to start with a VNT turbo.
This is how we used to increase the part load efficiency of steam turbines. Nozzles were arranged in groups, each fed through an independant control valve.
On 21st May, 2008 Paul S said:
Variable diffuser:
I think I'll stick with evolution (and my first guess) !!!
Your piccy is surely from something a bit bigger. :):):)
No arguement about the black box - dump valve it is.
I just think this turbo may be worth considering for the A-Series.
Anyone know if it is a KO3 or KO4?
they can produce more than 175hp as the new 207 rc will have 217 hp with the same turbo jsut more boost, they are ok not very big. i have had to change quite a few oil feeds to these turbo's recently and they are a pain to change lol. if i work on another at work ill take some pictures of it and how its setup on the 207 (same engine as the bini cooper direct injection ect)
not if youv halved the flow by dividing the ports paul ?*smiley*
looking at the rod from that black box to the turbine , i wonder if it allready had a valve shutting off one side of the turbine ?
Ben H
Member #: 184
Melton Mowbray, Pie Country
So has anybody seen any maps for these turbos? How do they compare to the popular GT17?
http://www.twin-turbo.co.uk
Ian_W
Member #: 40
Stratford upon Avon
as said above the black box is an integrated recirculating dump valve (electronically controlled).
one area that may make things abit trickier though is that the existing actuator is controlled using vacuum (from vacuum pump) similar to diesel VNT turbos instead of pressure, although it would be simple enough to put a more traditional actuator on.
From this thread http://www.northamericanmotoring.com/forum...ad.php?t=102987 it seem that someone has calculated that it is a similar size to the GT2052-1, if you look at the comp map for this (below) it looks like a good map (for high powerd 998 use anyway).
That's virtually identical to our estimated GT17 map.
I was reading the McInnes book about this last night. His theory is that although the flow rate is halved, the peak flow velocity ie. the top of the pulse is the same.
He is effectively saying that you can use the pulse energy as well the just the flow/pressure energy to spin up the turbine quicker.
i feel the average port velocity and density reduction may play a sufficiently negating role here to ofset the benefits ,so it would not compare with a true valved scroll. but improve a few 100 rpm on an open non split scroll.
There is a standard Wastegate actuator, the 'blackbox' has no protruding rod??
Or do I need a new pair of glasses*happy*
