Home > General Chat > camber
the shed
Member #: 317
How much negative camber do you boys run on ya cars when you do track days?
I am trying to sort the camber on my other mini not the shed dont worry *happy*
SON, WHATEVER FANCY SHIT YOU'VE GOT UNDER THAT BONNET, SEEN IT A MILLION TIMES
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
about a degree negative
AlexF
minimark
Member #: 19
newcastle
5 deg caster, 1/2 deg toe out, back 1/2 neg or 0
the shed
Member #: 317
fuck set mine at 2 degrees on the front looks good. I have to do it again !
mine is 2 degrees for track, same as miglias aparently
