Home > General Chat > Something a little bit different. Dellorto Carb set-up..?
Si P
Member #: 912
North Yorkshire
http://www.autosportlabs.org/viewtopic.php?t=1761
I think its a dellorto.
Si
mlarj
Member #: 2397
Plymouth
Thats mine! :)
Yes it is a dellorto you are correct. A mate worked for lotus some time back and managed to pick up a pair of dellorto 45's as used on the lotus esprit.
Currently putting some miles on the clock before I goto the local rolling road. Spoke to them this week and they are more than happy with me working with them configuring the Megajolt etc.
Si P
Member #: 912
North Yorkshire
Nice job. *Clapping*
Bulkhead box required or did you manage to get it all in without one. ..?
Also custom made plenum to, or is it a lotus item?
Si
Edited by Si P on 23rd May, 2008.
mlarj
Member #: 2397
Plymouth
A bulkhead box was required - see picture attached
Didn't have the lotus plenum so had to design one (not sure if the lotus one would be one big one or per carb?). Based my design on a weber/dellorto N/A K&N type air filter.
The combination of the dellorto and megajolt make the idle very stable - something I used to have a lot of problems with years ago when I had a SU - could have just been not setup correctly of course! :)
nice job , something allways wanted to do , and i even have the lotus dellorto too!
Anton
Member #: 764
Staffordshire
that plenum is pretty and would suit me rather well did you buy it or make it yourself?
mlarj
Member #: 2397
Plymouth
A friend of mine made it from the plans I gave him, almost 8 years ago! He was bloody good at what he did, you can't see any of the welds.
I think I am going to wait until the next MegaJolt firmware/software update (due fairly soon) before I take it to be setup properly. Would like to use some of the new features to control the electric fan via the Aux input, and the advance retard control.
It drives remarkably well considering I am using a combination of the Lotus jets and some I bought to ensure it doesn't run weak on boost.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I take it it works fine without restricter rings in the plenum then?
On 7th Nov, 2008 Nic said:
naeJ
m
mlarj
Member #: 2397
Plymouth
Yes, so far so good. I just have the standard dellorto trumpets inside the plenum
mini93
Member #: 2017
Warwick.
i like that! can i ask tho...whats the noise like? i had a dellorto on one of my mini's and sounded awesome o imagin this with the turbo has got to be even better
David.
Nice to see somebody using there Dellorto. Mine's still in "storage". Lol.
mlarj
Member #: 2397
Plymouth
Unfortunately the noise isn't as cool as a N/A engine on a weber or dellorto. There is a deep growl, but all a bit muted really.
mini93
Member #: 2017
Warwick.
i guess dampened by the plenum? ah well! definatly good going, id be interested seeing more piccys aswell, all custom manifolds i guess?
David.
mlarj
Member #: 2397
Plymouth
No custom manifolds just modified ones. Had to a file and grind in a couple of places to get clearance between the inlet and exhaust manifolds.
I suspect this might be avoided with the use of different inlet manifold, I wanted to use what I had in the garage.
