| Home > Help Needed / General Tech Chat > a and a+ valves interchangable? | |||||||
23rd May, 2008 at 09:54:14pm
hi, i have an austin 1300 gt head that i am modifying. obviously it has larger inlets and double springs, but was wondering about the exaust valves
23rd May, 2008 at 10:36:45pm
Why not shell out on some nice MS stainless race ones? OK £11 each but they must be good for a few extra bananas and they are new unlike 20 year old A+ ones. Edited by Jay#2 on 23rd May, 2008. On 7th Nov, 2008 Nic said:
23rd May, 2008 at 11:02:26pm
because iv just spent about 1k on panels and other little bits and pieces. im rebuilding completely near enough, and really cant afford to keep spending a few quid here and a few there, on things that arent essential. i will probably be upgrading engine componets etc in the future, but as i understand the a+ valves are excellent quality? |
23rd May, 2008 at 11:21:55pm
Just for reliablity, worth buying. Don't want your 1k's worth of panels stuck on the side of the road because a valve let you down. On 19th Jan, 2010 wil_h said:
24th May, 2008 at 09:31:49am
heed the advice above.......... the valves are intechangable as long as you use the same caps and collets for the A series which are single groved
24th May, 2008 at 09:38:33am
The pits on the valve faces will need to be ground away. This is the reason for reseating valves, and the reason why valve grinding paste is a waste of time.
24th May, 2008 at 10:17:17am
minispeed charged 33.64 for the 4 stainless exhaust valves 9.62 for the collets 6.75 for the top caps and 9 for the bronze guides .all plus vat ,he gave me a 10 percent discount by deciding i must be on minifinty forum i think even though i wasnt ,and told him so ,he was very freindly about it all .
Edited by robert on 24th May, 2008. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
24th May, 2008 at 12:22:47pm
if you want any second hand good A+ valves give me a shout
24th May, 2008 at 03:46:56pm
cheers but iv got a load of cylinder heads in the garage/shed.
24th May, 2008 at 03:56:45pm
yes the springs are interchangable use the inner spring loctars for doubles as well which the inner spring sits on
24th May, 2008 at 04:34:12pm
i will do. so are the a+ better than the a valves? |
24th May, 2008 at 06:34:20pm
Yes, they are much harder and the stems are chrome plated. On inlets it doesn't really matter. On 13th Jul, 2012 Ben H said:
24th May, 2008 at 07:01:41pm
cheers. il have a look at swapping them next time im home. many thanks |
