Home > Help Needed / General Tech Chat > Correct Crank Sensor?
metroturbo
Member #: 989
North Yorkshire
Is the first crank sensor on this page the correct one to use with Mr Fenton's excellent bracket? http://www.crankshaftsensors.co.uk/Product...8&e1=J6B&e2=J6B
The local scrap yard are bloody useless and could only find the shorter sensor (which I already have), and the robbing gits wanted £10 +VAT for it!
i think its the 2nd crank sensor that is the one you want, tbh though you could prob use both but the plug will be the difference, if that makes sense,
I'll see if the one I have has the ford part number on it, if so I'll post it up so you can then compare on that site with the OE part numbers.
All the ones I've sourced have been the longer type, and have come from Crossflow 1100 and 1300 Fiestas. The shorter type seem to be found in 1400 and 1600 CVH's in Escorts.
metroturbo
Member #: 989
North Yorkshire
Cheers.
