Home > 998cc > Your thoughts please
shane
Member #: 1246
Lowestoft, Suffolk.
I believe my 1275 blocks rings are shot, due to a house purchase funds are a little tight at the moment so am toying with making the best out of a bad situation and using what I have to save the day, can you please give your thoughts on the following.
12g940 head (Benross spec)
Pocketed 998cc block fitted with std998cc flat tops (engine covered no more than 4k)
R5GT T2 on mirage asy
Currently using std turbo verto clutch
S/C C/ratio box
MJ
Ford S2 Rs I/C
I have3 cam options avonbar P2 (currently in 1275) SW5 (currently in 998) and std metty turbo cam, after a little bashing of the search button, im a little confuse which to use, this is the part which is causing me most concern.
Im not looking for huge bananas, im running 6psi at the mo (1275) possibly looking to run more tho on this to get a few more nanans but not much.
Also what head gasket to use? I found when searching a few different options on this, who has fitted what and with what sucess rate?
Many thanks in advance.
Shane
Edited by shane on 31st May, 2008.
The only problem I see is getting the CR right. Assuming that your pockets are 1cc each then your chamber volume needs to be 27cc to make the CR 9:1 ish with the flat tops. If this is right then it looks like a goer.
Although I have no experience with the SW5, as it's in the engine I'd leave it there. The PH2 is a bit extreme and changing back to the Metro cam seems a waste of time.
The standard pistons are good upto 10psi with good fuelling and timing.
If using a 940 head then use the BK450, no other option. A good tip (if not already done) is to block the water holes in the block that rune close to the fire rings of the head gasket; there are 2 to fill, one behind No. 1 and one behind No. 4.
Get it done, bring it to Avon and you might win a prize. http://www.turbominis.co.uk/forums/index.php?p=vt&tid=223087
shane
Member #: 1246
Lowestoft, Suffolk.
Thanks Will, the only thing I have thought of that will be an issue is the drops, as the transfere gear is differnt (the drops are on my 1275 at the moment) may have to source one for the 998 crank or go helical?
Shane
At 6psi you'll have less than 100 bananas so helical drops in good condition and properly st float on the idler will be easily enough.
Advantage
Member #: 1450
Near Paris - France
Proof I used the search button, I am digging this old post
Anyway, I read 10 psi is OK on standart pistons : do we talk about A+ pistons ?
I am gonna use a 12G295 head, intercooler and the standart camshaft.
Since 10 psi is OK, I'll go for that in the end when fuelling and timing are right
What are the chances the transmission stays in 1 piece ?
What is the power expectancy ?
I have 80 to 90 in mind
Is it a shame to keep the standart camshaft ?
What gains are we talking about ?
Thanks in advance
Rusty by nature
Im using a 12G295 with a mild cam on my 998 Turbo. Engines running but turbo has not been fitted yet.
I'm planning on 12 psi max and hoping for 120hp. I have the standard transmission but have fitted a four pin differential.
I'm expecting problems with the verto clutch and have contingency plans if it slips.
I would expect you to get around 100 hp with 10psi and the standard cam.
I agree with paul. I'm running 8.5psi on a totally standard engine (6000miles so far) and reckon I have between 80 and 90 bhp. I use the MG metro cam and a 295 head.
Keeping the combustion completly free of det is the way to make the standard slipper pistons last.
wil, what milage was the donor engine? or was it rebuilt 6k ago?
shane, you can get fully floating 998 bushes to fit your primary for £17 from swiftune if that helps?
70, 000 miles before I turbo'd it! I've had it since 50k running in NA form around 60bhp.
Before me it was totally standard.
shane
Member #: 1246
Lowestoft, Suffolk.
Cheers but got my engine issue sorted joey, I bought a rebuilt 1293 engine off another tm member, just need the time to fit it now, which I doubt will be before xmas.
Shane
