Home > Help Needed / General Tech Chat > identifying a gearbox - A SM 22G1128 MOWOG
welshdan
Member #: 1111
s wales
hi, i have a gearbox with A SM 22G1128 MOWOG on it. any idea what model of mini this gearbox came from?many thanks
It was used accross the board. Could be an S. Count the teeth on the 1st motion shaft. If there are 17 its normal box, if there are 18 its an S box.
Double Post
Edited by MikeRace on 2nd Jun, 2008.
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Check for a number stamped on the lay gear, 22G1040 is a S laygear. 22G927 (i think) would be a standard box.
"Try to take over the world!"
The casing is not S, it's just a regular 4sync one.
littlejem59
Member #: 2544
Biddulph, Stoke on Trent
If my memory serves me right, in 1968 all gearboxes including the S changed to 4 sync. all boxes were same casting (22g1128) they could be had in remote and pre A+ rod.
It's not the age that makes me creak it's the mileage
