| Home > Help Needed / General Tech Chat > Rough Tickover | |||||||
2nd Jun, 2008 at 08:22:43am
The tickover on the road 998T is rough. A quick play around yesterday shows that cylinders 3 and 4 are missing at tickover i.e. pull the lead off and it makes little differance. Otherwise the car runs fine, smooth and no oil burning etc.
2nd Jun, 2008 at 08:49:02am
I would start by checking the pulley to sensor clearance.
2nd Jun, 2008 at 08:57:17am
here's a test for it, add 180 degrees onto all the points, swap the leads and try that if you can? would prove that theory?
2nd Jun, 2008 at 09:54:24am
tappets wil ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
2nd Jun, 2008 at 10:40:21am
On 2nd Jun, 2008 robert said:
tappets wil ? Even though the compression results would suggest all was ok, I wondered if slighty tight clearances might be an issue. This is because my first instinct was that a leaking valve would produce the symptons seen. I'll change the sensor later and check its position. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
2nd Jun, 2008 at 10:45:10am
wil, do a compression check with all the plugs in only removing the one at a time to be tested and then note the results
2nd Jun, 2008 at 10:55:21am
Good tip, Steve.
![]() 2102 Posts Member #: 432 Post Whore Swindon |
2nd Jun, 2008 at 11:02:32am
how old is your kid these days? ready to take over from the missus in the garage? lol
Edited by Mini_Andy on 2nd Jun, 2008. |
2nd Jun, 2008 at 12:20:26pm
Girls don't know what a throttle is, at least they don't relate it to the accelerator. On 7th Nov, 2008 Nic said:
2nd Jun, 2008 at 12:54:56pm
have you got enough rotational angle between the sensor and notch?
2nd Jun, 2008 at 01:11:05pm
On 2nd Jun, 2008 iain said:
have you got enough rotational angle between the sensor and notch? just remember, mine didnt like compensating too much for some reason. The MS has been on for about 3 years now and been fine, I haven't changed anything, but I guess the sensor could have moved, I'll have a look. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
2nd Jun, 2008 at 08:40:00pm
Well I tried everything tonight, and no change. All compression reading are good, I don't understand it.
2nd Jun, 2008 at 10:33:59pm
could it be something as simple as a manifold gasket leak?
3rd Jun, 2008 at 12:41:15am
sounds like something silly. Changed all your plugs & leads etc? On 19th Jan, 2010 wil_h said:
3rd Jun, 2008 at 07:22:28am
are you sure she is not running lean as this will have the same effect mate always looking for them bigger bunches of bannanas |
3rd Jun, 2008 at 08:04:55am
Not a bas idea Budd, I'll give it a go. But I noticed a bit of emulsion in the rocker box, so I'll probably change the gasket anyway.
On 3rd Jun, 2008 milamber said:
sounds like something silly. Changed all your plugs & leads etc? Yep done all that. Even changed the EDIS and coilpack and tried unplugging the MS. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
4th Jun, 2008 at 08:51:58am
Well i lifted the head last night and the gasket looks fin as do all the valve seats. Hummm. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
4th Jun, 2008 at 06:05:07pm
I had a similar problem when I changed to a different inlet manifold wil.
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
5th Jun, 2008 at 08:41:53am
Mine did exactly this 2 weeks ago (although i have not got MJ) only running on 3 cylinders (ish) and pulling 3 or 4 made no difference
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
5th Jun, 2008 at 05:04:43pm
i recently fitted a (modified with a vac take off, but only a 3mm spacer due to bulkhead) minispares intake instead of a MG metro with a 0.5inch spacer and that does affect idle quite a bit as well.
Edited by Sir Yun on 5th Jun, 2008. That sir, is not rust, it is the progressive mass reduction system
5th Jun, 2008 at 05:18:32pm
Heeeey, that's interesting. I have never been able to get a decent idle out of any engine that I have had in the mini. The only common part (and I have changed everything) is my MS manifold. Hmmm. On 7th Nov, 2008 Nic said:
5th Jun, 2008 at 05:26:12pm
I had both the widebands working on my 998 last weekend. Measuring AFRs on inner and outer cylinders.
5th Jun, 2008 at 06:49:03pm
id be really interested in the mixture variance on the turbo manifold with a hif paul ,
5th Jun, 2008 at 07:14:37pm
On 5th Jun, 2008 robert said:
id be really interested in the mixture variance on the turbo manifold with a hif paul , specially at 4k and up , it may explain the piston and head gaskets blowing ,if no4 and 1 are running a few afr points lean ? The earlier logs are in this post: http://www.turbominis.co.uk/forums/index.p...tid=190001&fr=0 Same sort of readings. I'm afraid the opportunity to test other manifolds has passed. The EFi is now back on the car. The log design of the turbo manifold may have been developed because BL knew that there was a distribution problem and needed to do something about it for a turbo application. Not sure this helps Wil though as his problem is with 3 & 4. I would double check that you are not getting an air leak on that inlet tract. Edited by Paul S on 5th Jun, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
