| Home > Technical Chat > inlet temperatures, boost and nanas.. | |||||||
3rd Jun, 2008 at 09:27:55pm
Just wondering if anyone knows what their inlet temperatures are and at what boost? And what power you got at that temp?
520 Posts Member #: 2093 Post Whore Grenoble, France |
3rd Jun, 2008 at 11:24:56pm
I saw on my Mini at 105kpa (instead of 95 ambient) temperature elevation was 4 degrees. Then I moved the IAT. Edited by alpa on 3rd Jun, 2008. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
23rd Jun, 2008 at 06:23:24pm
Mat.
23rd Jun, 2008 at 06:36:08pm
The DON rarely goes over 40 deg.
23rd Jun, 2008 at 09:33:08pm
23rd Jun, 2008 at 10:44:21pm
Without my cooler I was seeing around 60 degrees on VERY low boost (6-7psi) now its about 25 degrees at the same boost. Looks like the IC is doing its job. Im going to take some logs when I get the chance to wind the boost up!
24th Jun, 2008 at 08:56:09am
On 23rd Jun, 2008 matty said:
Tom thats good going to keep it below 40 degrees...what boost was that with? According the famous Honda F1 turbo study the best they were getting was with a 40C air temp. And a rather high fuel temp, around 70C I believe. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
24th Jun, 2008 at 11:59:27am
16psi, we've never run any more than that.
1st Jul, 2008 at 04:38:34pm
Did some more data logging, and im now getting 33 degrees at 10PSI with an ambient temp of 22 degrees. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
1st Jul, 2008 at 05:27:49pm
what where you seeing before you had the intercooler fitted? Team www.sheepspeed.com Racing
1st Jul, 2008 at 11:27:57pm
Urm.. at 7 psi 60-80 degrees depending on how long I was on boost for (generally not very long either) https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
2nd Jul, 2008 at 12:53:07am
Hows the mapping going lately, did you manage to get the idle manifold vacuum down with the mods to the plenum or are they still the same. On 26th Oct, 2004 TurboDave16v said:
2nd Jul, 2008 at 08:45:12am
All the vacuums seem constant now. Vacuum at idle is about 50kpa.
Edited by matty on 2nd Jul, 2008. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
2nd Jul, 2008 at 09:52:38am
On 1st Jul, 2008 matty said:
Urm.. at 7 psi 60-80 degrees depending on how long I was on boost for (generally not very long either) ![]() eeek! thats a little on the warm side Team www.sheepspeed.com Racing
1st Jun, 2009 at 12:36:21pm
I managed to do some more fine tuning over the weekend as the new clutch is allowing me to run more boost.
1st Jun, 2009 at 02:35:13pm
your temps are about the same as mine matty at 15psi, I find the air temp rises approx 1.5 degree for each extra psi of boost Team www.sheepspeed.com Racing
1st Jun, 2009 at 03:05:12pm
On 1st Jun, 2009 matty said:
After reading the thread on inlet temps I data logged my drive and at 15PSI the inlet temps were mostly at 35 degrees and once it hit 38 degrees, with an ambient temp of about 27-28 degrees. It just goes to show how efficient the 2wd cossie cooler is with a good air flow through it! |
1st Jun, 2009 at 03:14:52pm
All I know isn that the two pipes to and from the I/C are at completely different temperatures(by feeling them after a fast run) and that I have got away with bursts of full throttle at 16 psi -so far.
