Home > Help Needed / General Tech Chat > Modify the batterfly shaft.....
Giancooper
Member #: 2402
Reading the Vizard book (Tuning the A-series engine) he say that we can improve flow of the hiff 44 cutting one-half of the throttel shaft.... what we think?
Like that:
Edited by Giancooper on 9th Jun, 2008.
This is a worth while mod. although it will make bigger gains on an NA motor.
None of my turbos have it done.
Giancooper
Member #: 2402
Do you think is not a good modify for a forced induction engine? *Rofl!*
might be worth fitting a dump valve if your weakening the butterfly shaft?
I think it will have less of an effect in a turbo application.
The airflow through the carb is governed by the turbo, so relieving this slight restriction will just mean that the turbo has to work slightly less hard (and I mean slightly).
In an NA application the less restrictions the better.
If you have time on your hands then do it, but it's lot's of effort for little gain IMO.
I did this to mine a couple of years back, unfortunately i ended up with a bent shaft *surprised*
did you have a dump nic?
Getting a Bent Shaft usually occurs because of inexperience Nic!
Nick
Member #: 154
Midlands
didn't fancy cutting mine in half so just thinned down both halves.
