Home > Help Needed / General Tech Chat > Actuator Rod Clip
Ric
Member #: 36
Basingstoke
I took my actuator off again yesterday and managed to lose the little 'C' shaped retaining clip that holds the arm to the pin on the wastegate flap thing.
Has anyone else done this, and if so where did you find a suitable replacement? I tried alexb's method, but he must have more better fabrication skills and more bendy fingers than me as i couldn't get it to work!
I lost the one of my GT17, it's currently held on with a bit of wire.
Mine too - a bit of paperclip
I think they are the same size as the C clips holding on the rods onto the door locks if you have a spare door kicking about
Hmm i need a few of these (for the doors) I imagine theyre very inexpensive.
I may buy some and sell them to people.
Ive bought some so ill let you guys know when they arrive.
Who ever needs some ill send them out for some beer tokens or (preffered payment method) Nudy pics of wives/gfs.
i use wire mate
mini93
Member #: 2017
Warwick.
got loads spare at work :p they have a habit if flying off to the darkest corner of the room, under the crappiest work bench ever
there not the most dangerious bit tho :p
David.
Ric
Member #: 36
Basingstoke
I've bought some weird clips that will hopefully do the job, but if not, what wire do you use?
Most of my stuff is either too thin, or far too thick.
welding wire
Look for "e clips" on ebay. Bag of assorted sizes for about 99p.
motorworld sell assorted boxes of e clips
Ive used them several times when im stuck, but theres only the one in there the right size (if your lucky)
bit of wire for me, but then i got fancy and have an R clip in there *happy*
obviously its needed for such an item that needs to be removed quickly... *happy*
turbo hogster
Member #: 178
stowmaket suffolk
r clips are the best bet buy the way
Ric
Member #: 36
Basingstoke
I was looking for r clips today, but just lashed a random spring clip thing on. Seems to have held up so far though.
Will get some e or r clips ordered. :)
