Home > Help Needed / General Tech Chat > Can anyone tell me the correct tappet clearance???
holmesgraham
Member #: 2556
Southport, Merseyside
Hi, Does anyone know what the tappet clearance is on a mini turbo with 1.5:1 rockers and an med t3 cam? what is the standard clearances and do people set the exhaust valves slightly wider to allow for expansion from heat? thanks graham
Clearances can depend on the cam, I'd contact MED if they supplied it.
holmesgraham
Member #: 2556
will ring them n post what they have to say! thanks
holmesgraham
Member #: 2556
They recommend 16 thou.
