Home > Help Needed / General Tech Chat > Broken Plenum chamber
TomBooth
Member #: 2814
Mansfield - Notts
Alright there, Noticed today whilst I was checking a few things that a take off from my plenum has snapped off!
Just curious if this can be fixed? Looking at it it looks like its been pressed in there, as where its snapped its bent and has quite happily come away from the plenum. I was wondering if these are a pressed fitting and if there replaceable?
Many thanks
Tom
If all else fails you could drill it out tap it to a small fitting.
tadge44
Member #: 2500
Buckinghamshire
I would just dreill out the remains,tap it and screw in a replacement turned up on the lathe(depends if you have access to a lathe of course !)
Or if you love a bodge, a piece of tube JB welded in will last forever.
I have an extra takeoff for my fuel regulator (as I didn't want a bleed valve in the fuel reg signal line, and I use the one you have snapped off for the actuator). I bought a threaded union from demon tweeks and drilled and tapped a hole and screwed it in.
Star Mag
Member #: 375
Leicestershire
Mines blanked off also and has a fitting on the other side.
