| Home > General Chat > geometry change under power | |||||||
15th Jun, 2008 at 03:05:45pm
have a look at how the front wheel position in relation to the wing changes under power ,wonder what that does for geometry and handling ?
326 Posts Member #: 1323 Senior Member |
15th Jun, 2008 at 06:00:16pm
that's why front wheel drive are set toe out , rear wheel drive toe in
15th Jun, 2008 at 09:19:35pm
It has to be said that the whole subframe moves on that car not the suspension.
http://www.twin-turbo.co.uk
16th Jun, 2008 at 09:24:27am
often when the miglia and even seven are on the rolling road (with the front end off) you can see the whole subframe twisting under the load. Team www.sheepspeed.com Racing
16th Jun, 2008 at 12:24:26pm
Ya that Movement is quite common Infact one of our racers managed to brake to mini spares solid sub frame mount at it’s last dyno run witch really confused us as un like some of you guys it was only running 128 hp and 110fp torque my dyno guy recons that it is the role cage setup we use making the car so solid meaning the only place left to give is there I suppose its the old chain and weakest link scenario, isn’t the yoke on the dyno a starlet conversion tho ? On 17th Feb, 2009 Rob H said:
16th Jun, 2008 at 12:44:42pm
I'm so glad that I've not got a flappy front-end. In the 13's at last!.. Just |
16th Jun, 2008 at 12:53:44pm
On 16th Jun, 2008 Jimster said:
often when the miglia and even seven are on the rolling road (with the front end off) you can see the whole subframe twisting under the load. Jim, where does the subframe twist? Paul I seriously doubt it! |
16th Jun, 2008 at 01:19:45pm
mainly the main towers, but it's hard to tell, next time the migs are on the rollers I'll take my cam on a tripod Team www.sheepspeed.com Racing
16th Jun, 2008 at 01:36:16pm
I've always thought that it must be a bad thing to have the rack mounted on the shell rather than the subframe. On 28th Aug, 2011 Kean said:
16th Jun, 2008 at 02:18:04pm
thats for sure Mini 13 on my own race car I have mounted the rack on the subframe not a big job the only thing you need to do is increes the size of hole it fits trough in the bulk head and fet a metalastic coupling between the coloumb and the rack to alow for movment or elce your steering could lock not nice ! On 17th Feb, 2009 Rob H said:
