Home > Help Needed / General Tech Chat > OT audi seats
I have a set of black Audi seats for my camper, i think they might be from an s3, problem is they are electric operated and heated, where can i find a wiring diagram for them ?
if not ill sell them and buy something else
A3 haynes manual should have what you need?
£21 though Tom i only paid £40 for the seats lol
I am a twat
ill pop to the library and photocopy the pages
Keep your eye out on ebay mate! Or alternatively wait till no one is looking in Halfords and open the plastic packet and have a look LOL
I've had a look and I might be able to help you here. What wiring have you got coming out of the seats? Are the switches built into the seats? Some pics would help.
ok ill go get some now
The switches
The wiring
I think by looking at the wiring the Brown is earth the red/white is power to switch and the black and blue is heaters in seat
these are now for sale if anyones interested, got myself a bargain pair of porsche seats
Edited by wolfie on 22nd Jun, 2008.
my guess would be brown live, earth would be through the bracker, the other wires are for heater, and bum sensor
graemec
Member #: 1424
Carnforth, Lancs
I'd be with Jim. To power the motors and the heaters the live will need tobe pretty beefy - so brown for that one.
One wire for bum sensor output
One wire for triggering heater (via relay?)
Could be something for seatbelt pre-tensioners and/or seatbelt warnings?
Other problem would be these could be using some fancy arse data system to an ECU in the seat, not a simple +12v and ground switching system.
are the airbags in the seat?
good point Rob
i have just checked and yes they have airbags, i need to remove these really dont i
Any idea what year car they are out of Neil? I have all the Audi wiring diagrams here on a software program, but so far the years I have tried don't tally up to the wiring colours you have.
Thus far the wires just feed to the switches, which then in turn feed the motors, nothing fancy. There should be a brown wire 2.5 sqmm that is earth, and a red/white that is 4 sqmm as live, however that must be for a different year of motorised seats.
You should be able to work out the heater wires from measuring their resistance?
The earth you could check by checking continuity with the frame of the seat. They might be bonded together somewhere?
Edited by matty on 17th Jun, 2008.
they look like late A3 or A4 sport seats. I've just checked the wiring for mine and have 8 separate wires and 3 multiplugs so no use I'm afraid
Dicanio
Member #: 91
The seats look similar to those fitted in my A4 S-Line. The picture would suggest that the seats are manual adjustment in the main, the four way switch on the side opearted the electric lumbar support.
The handle on the right (of pic) operates the forwards/backwards, the one on the left operates the front tilt (knees) and the one on the side is for the height.
all i know is they were from a sporty model A3 but i have never seen these in an A3
graemec
Member #: 1424
Carnforth, Lancs
If the main functoins are mechanical then I would just bid bollox to the electrickery bits!
You'll probably struggle to remove the airbags without dismantling the seats completely
