| Home > Help Needed / General Tech Chat > MS X pin diff grub screw thread | |||||||
20th Jun, 2008 at 10:50:41am
I got my x pin diff the other day but unless I am going mad there isn't a grub screw in the box. MS say it would be best for me to source my own. I am at work and may knock off early to head to my local nut and bolt man but to give me a head start does anyone happen to know the thread of the screw? It's a long shot I know.
On 7th Nov, 2008 Nic said:
20th Jun, 2008 at 11:37:15am
Strange - mine came assembled and I had to take it apart to fit the output shaft.
20th Jun, 2008 at 11:44:43am
The ones I have fitted have had a capscrew too.
20th Jun, 2008 at 12:47:29pm
No youse guys are right, it's cap head. I guess I will go home and take the diff into the screw shop. Might not get the box built up this weekend then On 7th Nov, 2008 Nic said:
20th Jun, 2008 at 12:52:09pm
Yes the bolt is a cap head as in PIC I am not back in my work shop just happned to have this pic on my phone the bolt is the same tred as the bolts that hold the gear box to the crank cace some one on here should know what that is,
On 17th Feb, 2009 Rob H said:
20th Jun, 2008 at 12:55:33pm
Most likely 1/4" UNF then. Schrödinger's cat - so which one am I ??? |
20th Jun, 2008 at 01:01:09pm
Its mont deffently UNF and its smaller than 3/8 so must be 1/4 Problam solved :) On 17th Feb, 2009 Rob H said:
20th Jun, 2008 at 05:03:00pm
Fantastic, thanks guys. I didn't get tonight but I will pop out tomorrow and then the rebuild will comence. Turbo Minis is great! I feel a donation coming on. On 7th Nov, 2008 Nic said:
