| Home > Help Needed / General Tech Chat > 28cc head | |||||||
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
3rd Aug, 2004 at 04:31:32pm
How much boost will be safe then with a 28cc head and Intercooler ??? Edited by b12 on 3rd Aug, 2004. TurboLessTosser |
3rd Aug, 2004 at 05:12:26pm
I've know of people to run 18psi on stock pistons... I'm sure others will say the same.
3rd Aug, 2004 at 07:58:10pm
Of course young man !!
TurboLessTosser |
3rd Aug, 2004 at 10:01:02pm
Take it the person using stock pistons you know of is stu dave?
Edited by iain on 3rd Aug, 2004. |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
3rd Aug, 2004 at 10:02:31pm
bodge it one has always had stock pistons in and often saw 20 psi and when i took the head off they were perfect. Everyone knows that instructions only have to be read if the thing doesn't work....
4th Aug, 2004 at 08:52:46am
4th Aug, 2004 at 12:36:46pm
std psitons loook like a good design, so its not surprising they can handle the power!
AlexF |
![]() 198 Posts Member #: 345 Advanced Member Guildford Surrey |
4th Aug, 2004 at 02:04:04pm
For reliability we would only run the standard pistons on 1 bar of boost and this would be using a turbo management ignition control unit using a pressure sensor in the plenum If all the mods are done correctly 14 psi is approx 150+bhp !!! all you have to dio then is use a traction control system so you can put the power down !!!!!! |
4th Aug, 2004 at 02:07:50pm
Avonbar Racing Please explain what is meant by turbo management ignition control unit using a pressure sensor in the plenum TurboLessTosser |
4th Aug, 2004 at 02:55:21pm
traction control???
AlexF |
4th Aug, 2004 at 07:13:58pm
Suspension geometry is more important to traction!! Cant say i can think of any good traction control systems either!!
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
5th Aug, 2004 at 10:59:31am
I think Avonbar may mean mappable electronic ignition. You have a pressure sensor so that the ecu can adjust the timing to take into account the level of boost present. Alsdo means you can still have good timing for around town of boost driving. Really i'd suggest everybody has one, they are not hugely expensive and so much better than a dizzy. Or maybe they are talking about controling the waste gate actuator through the ecu (or seperate control unit). These have solenoid valves in them. The waste gate stays shut untill the required pressure is reached then the valve pulsates at a frequency that allows pressure into the actuator to open it and blled of the surplus exhaust gas.
5th Aug, 2004 at 12:40:18pm
std pistion AE 20813 ??
Edited by AlexF2003 on 5th Aug, 2004. AlexF |
5th Aug, 2004 at 01:13:00pm
"not hugely expensive"???
![]() 1128 Posts Member #: 142 Post Whore Winchester |
5th Aug, 2004 at 01:18:18pm
20831? |
5th Aug, 2004 at 01:23:39pm
So hijacking slightly, I was looking at a Boost Retarder unit from (I think) Microdynamics in the Tweeks catalogue, however, I tried to contact Tweeks, they had no details of the function of the unit, and the email they gave me for Microdynamics didn't yield a response.
5th Aug, 2004 at 01:36:39pm
Several guys run Emaerald systems...
AlexF |
5th Aug, 2004 at 01:44:01pm
1) No (thankfully)
5th Aug, 2004 at 03:57:51pm
A ha. Sounds like a bag of sh1te to me then.......
5th Aug, 2004 at 04:32:33pm
do a search tom theres plenty on here about that subject!
AlexF |
5th Aug, 2004 at 08:47:55pm
As Alex says!
5th Aug, 2004 at 09:13:31pm
I agree with dave on several comments.
5th Aug, 2004 at 10:46:54pm
"Stu"...if we are talking about Mr wright then he does run standard piston..BUT..Machined out to give a bigger dish..How do i know??..I saw them at Avon when he had his head off.
146 Posts Member #: 350 Turboing minis since '89<br> Supercharging minis since '04 |
10th Aug, 2004 at 05:35:26pm
depends how efficient the intercooler is, i have run 14 psi on a standard engine- (ok with bp8es plugs and a bca needle and timing set to 25.@5000rpm)with a vectra turbo diesel intercooler plastic ended job , it was before having a rolling road but it didn't pink and must have had 130 bhp |
