Home > Help Needed / General Tech Chat > Turbine housing to air filter. What size pipe???
holmesgraham
Member #: 2556
Southport, Merseyside
Hi! Can anybody tell me what pipe i need to run from my compressor housing to my air filter? What is the Inside diameter of the pipe used?
Will this do??
http://cgi.ebay.co.uk/BLUE-SILICONE-HOSE-3...1742.m153.l1262
Thanks - Graham
Im sure its 60mm on a T3 (if thats what your using)?
I used 60mm on mine (T3)
i concur
holmesgraham
Member #: 2556
Yeh am using a t3. Thanks alot ppl!! help is really appreciated.
Ollie
Member #: 1380
Just thought I'd bump this up. I was hoping the answer to my question would be here (60mm) - after 2 mins of searching I found it.
+1 for search function
Edited by Ollie on 1st Mar, 2010.
nibble36
Member #: 4273
stoke on trent
ok i got the pipe from avon bar and it 57mm it wont fit so dont get it from there i had to buy some 60mm that fit ace good luck +its not cheep
I got some of ebay - 50cm x 60mm for less than £10 delivered.
Ollie
Member #: 1380
Perhaps I found the same shop as you Andy.
I ordered 1m in the end as I noticed Avonbars pipe was 800mm. Thought I would play it safe as I was unsure if 500mm would be enough.
Is there any one who knows roughly what length they used? Not that I need to know but thought if anyone searching back though found this it may be of use to them. :)
Danishwonder24
Member #: 10046
Wolverhampton, West Midlands
bump this thread up one more!! 60mm all the way... don't forget to buy metal lining when the turbo begins sucking... and it GETS very hot
