| Home > Help Needed / General Tech Chat > Gearbox rebuild problem --- what I found | |||||||
152 Posts Member #: 2190 Advanced Member South Carolina, USA |
28th Jun, 2008 at 08:28:37pm
What did I do wrong????
Edited by Mikes1098 on 30th Jun, 2008. |
28th Jun, 2008 at 08:55:45pm
Do you have a photo of it from the top (looking down on the mainshaft) ??? Schrödinger's cat - so which one am I ??? |
28th Jun, 2008 at 09:10:25pm
There is a cross section of the first and second gear assembly in the Haynes manual, it shows the interlock plunger inline with a “cutaway toothâ€â€¦.can it only go on in one orientation? I simply lined up the baulk ring grooves and put the interlock in after is was assembled…
Edited by Mikes1098 on 28th Jun, 2008. |
28th Jun, 2008 at 09:50:04pm
Can you do it manually, i.e pushing it over with a screw driver? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
28th Jun, 2008 at 10:43:22pm
I can not move it with a screw driver either….
29th Jun, 2008 at 08:58:19am
Hmmm, 3 synchro box, years since I worked on one of those so I won't be much help.
30th Jun, 2008 at 02:28:56am
Here is what I found…hopefully this will help prevent someone from making the same mistake. From what I understand this can only be screwed up on a 3 synchro gearbox… the 4 synchro can be installed in any direction.
30th Jun, 2008 at 07:42:42am
Great! I hope I dont need it (ie. work on a 3sync one again ) :) On 13th Jul, 2012 Ben H said:
148 Posts Member #: 98 Advanced Member Slovenia |
23rd Jun, 2013 at 08:43:47pm
many thanks!
