| Home > Help Needed / General Tech Chat > flushing exhaust | |||||||
![]() 1342 Posts Member #: 2292 Tool Herne Bay, kent |
30th Jun, 2008 at 07:36:07pm
basically i been told that one of the main reason my car is smoking alot is cos the shit still in exhaust
cant beat a good blowout. |
30th Jun, 2008 at 07:37:07pm
petrol or something similat that will evapourate. |
30th Jun, 2008 at 07:38:27pm
will that get rid of any oil and shit in the ehxaust pipe? On 27th Apr, 2010 Rick.SPI said:
30th Jun, 2008 at 08:26:57pm
To be honest by the time you've taken the exhaust you could of run the engine and cleared the exhaust of shite. A quick blast up the road will do the trick. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
559 Posts Member #: 2775 Post Whore Aberdeen |
30th Jun, 2008 at 08:31:12pm
A decent thrash around some country roads should do the trick. Get the exhaust nice and hot and the crap will just burn away. |
30th Jun, 2008 at 08:41:02pm
As above, get the system stinking hot and any crap will burn away.
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
30th Jun, 2008 at 09:49:31pm
I take it you took the car to bill in the end, what else did he have to say?
30th Jun, 2008 at 10:28:40pm
I would use some petrol to sort of loosen the debris first. Then go out and drive it hard! On 13th Jul, 2012 Ben H said:
30th Jun, 2008 at 10:56:55pm
And take a fire extinguisher with you! On 7th Nov, 2008 Nic said:
30th Jun, 2008 at 10:59:21pm
block one end up with a potato and go to the chemist and get some caustic soda you will need ID to get this and questions will be asked ... what for etc .....
Edited by BENROSS on 30th Jun, 2008.
30th Jun, 2008 at 11:07:13pm
bit of a mad idea, but wouldnt gently spraying water into the inlet steam clean the exhaust somewhat? "Turbo's make torque, and torque makes fun"
30th Jun, 2008 at 11:26:07pm
yes joe mad IDEA!....LOL
1st Jul, 2008 at 07:32:43am
On 30th Jun, 2008 joeybaby83 said:
bit of a mad idea, but wouldnt gently spraying water into the inlet steam clean the exhaust somewhat? It's much better using petrol. LOADS. Water is a bit fag. On 13th Jul, 2012 Ben H said:
1st Jul, 2008 at 08:00:05am
What about pouring sand into the intake while the car is running?? This would sand blast all this sh!t off plus port the head at the same time 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
1st Jul, 2008 at 08:02:16am
now thats a clever idea! it would even make the nice rough surface in the ports aswell, not this polished shit everyone makes! Edited by miniminor63 on 1st Jul, 2008. |
1st Jul, 2008 at 08:03:12am
Im sure the results would be Spectacular! lol. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
1st Jul, 2008 at 10:34:58am
I used caustic soda on an old 2-stroke bike exhaust some years ago to good effect. It was much easier to handle though! |
1st Jul, 2008 at 11:55:46am
Just thrash it !! |
2nd Jul, 2008 at 07:09:26pm
this is not achually that bad, the only problem is the exhuast rattles quite abit afterwords untill the sand is compleatly out but it ported the head very well, also now have a slight overbore. lots of power!
On 1st Jul, 2008 MikeRace said:
What about pouring sand into the intake while the car is running?? This would sand blast all this sh!t off plus port the head at the same time Drives
