Home > Help Needed / General Tech Chat > oh dear?
jamz
Member #: 2292
Tool
Herne Bay, kent
how do i no if my drop gears are fooked
cant beat a good blowout.
What's your symptoms? What makes you think they're fooked?
Loud whining is a usual indication
Does that mean my straight cut drop gears are fooked? *wink* *tongue*
Mine made this sound.. EEERRRRRCCCCHHHHHH CRRRRRRUUUUNNNCCHCHHHHH GRRRRRIIIIINNNNNDDDDD.
And then I lost all drive.
lockfast
Member #: 2775
Aberdeen
Might not be your drop gears but you can safley say something is fooked!
have you been winding the boost up james
jamz
Member #: 2292
Tool
Herne Bay, kent
nope... jsut on the motorway sounded it slowed down and soudned abit whiney
could be a cv, could be the cranks snapped, need a bit more info
does it crunch if you push the car with the clutch in?
pristic
Member #: 1774
Sydney AUS
Hmmm, my stocko 1100 box is whiney - standard helical and a 3.765 diff... cruising along and it kinda rings in your ears... ah, she'll be right.
If it broke at high speed, id pull out the sump plug and change the oil, see how many chunks of metal on the sump plug magnet... if its broken a diff there will be shrapnel everywhere, same for the rest I guess. broken cranks make a massive knocking noise I heard, depends where they let go I guess.
Can you select gears if your sitting still?
If you roll it with clutch in whats it do?
Sounds nasty mate... good luck
Pete.
1132cc Turbo ~120 bananas ATW - Fun Fun Fun
