Home > Help Needed / General Tech Chat > Switched live
t3gav
Member #: 229
Gavin@minispares.com
kent
Hello just wondering where people wire the switched live on the edis module? I also need a switched live for the alternator and fuel pump, would using a terminal on the fusebox be ok or is it likely to melt lol? Cheers
My MS is fed straight from the fusebox on a switched link.
My pump is fed direct from the battery via a relay that is fed from the MS (sort of)
On the MJ/EDIS bits, I've taken it off one of the thick switched lives that come from the ignition barrel, with an in-line fuse for each.
t3gav
Member #: 229
kent
Cheers :)
