Home > Help Needed / General Tech Chat > Manifold Nuts
Turbo Rich
Member #: 551
Ashington W.Sussex
My manifold nuts keep coming loose. I am using the brass nuts type with the 3 centre ones on the the thick washers and the 2 ends on thin/small washers. Are there supposed to be spring washers on them aswell? The problem with the brass type is that they are so soft I'm worried each time I tighten them up that I'll mash up the threads which I have done a number of times. Any tips on this or are there better nuts I can buy?
Rich
Bin the brass and use steel ones. I don't use a spring washer, just get them tight. Never had one rust up.
Turbo Rich
Member #: 551
Ashington W.Sussex
Cheers, I'll see if I can find some.
PaulH
Member #: 2340
Dublin Ireland
Mini Spares sell a very nice 12 point nut and stainless steel stud I use them on all the racers there ubber good a little copper slip when you put them on then when you go to take them off one turn with a spanner to crack them and then back them out with your finger every time.
regards,
Paul.
On 17th Feb, 2009 Rob H said:
I use these too. They are really good and made by ARP if I remember correctly.
Turbo Rich
Member #: 551
Ashington W.Sussex
Cheers guys, will get some of these then. Ouch at the price!!
