Home > Help Needed / General Tech Chat > Will i get away with cast pistons?
Monkeh
Member #: 1997
Lichfield
Hi. ive had some forged accrelites on order with avonbar since the beggining of the year now and i still aint got them. Im at the stage now where i need pistons. i plan on running 15psi of boost with a cr of about 8.2:1 so i ordered a set of 14cc forged accrelites. do you guys think a cast item would be ok instead?
its not an every day car so they're going to take a bit of abuse.
the only options i think i have is either grow old waiting for these accralites or get a more available cast piston.
any advice ??
thanks
OMEGA cast pistons are superb and have a top record for durability for turbo application
available in 11cc dish
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
These are the puppy's ive got, will be running similar boost if not more I think they'll be ok!
If the piston is of sound construction, AFR's are sensible, and you dont detonate the crap out of them....then they will not break.
I ran standard turbo pistons at 20psi for 2-3 years, day in day out and the only problems I had, were self inflicted ( I melted a couple )
Also used cast pistons in various engines...again, if good design, there wont be a problem.
Most Subaru engines used cast pistons too.
Most notable thing to avoid, is any with split skirts, or a big slot for oil control.
The skirt must be sound, with oil holes behind the scraper ring. No slots.
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
right about cast pistons,
but if you have the budget for forged ,and just have trouble with waiting, why not buy omegas bowl forged?
Monkeh
Member #: 1997
Lichfield
thanks for the replies,
do the omega 11cc pistons have the same deck volume as standard pistons?
fab
Member #: 100
Paris' suburb
nope,they (omega) have a smaller deck height, from memory dif was 0.7mm.
stefaz
Member #: 1656
stoke-on-trent
my accralites came today - maybe worth a call?
Turbo Tel
Member #: 588
Delaware, USA
As most know I managed to drop the lands off of 2 sets of Mega's total cost over 400quid... Maybe there was a bad batch because I know they have a great reputation as do the Omegas but do a search and see if you can find a post where Forged pistons have dropped lands....I never found one, you will find Plenty of forged though.
As far as I am concerened ! Shoulda got the Accralites in the first place..
Terry
eaton_mini
Member #: 1649
West Sussex - dreaming of forced induction!
Monkeh, what size accralite you after?
turbo hogster
Member #: 178
stowmaket suffolk
well after some mishaps and problems im still using my mega piston set, but for higher boost than 15 psi then the omega's would be a better bet if you can get some, or even powermax.
the only grip i have with the mega range is the ring gap size is to large, eg oil control is between 40 and 50 thou were the comp ring are about 14-16 thou oil control shouldnt be much bigger than 12 thou.
so when i lift of then oil getts sucked up passed the oil control rings causing a nice puff of blue smoke when i re apply the go lever.
Monkeh
Member #: 1997
Lichfield
im waiting on the 1293 14cc dish accralites eaton_mini
Turbo Tel
Member #: 588
Delaware, USA
Thats exactly what I have in now, beauty is they drop the compression to around 8.5-1 without any head mods...
However, I waited almost 6 months.. A real bugger but unfortunately Ian is at the mercy of his supplier and I'm gessing is backordered all the time until they get their fingers out. If you can afford them I would wait--- he'll get them out soon..
Terry
stefaz
Member #: 1656
stoke-on-trent
I got mine this week and only ordered them last week (14cc +0.020") - give him a bell mate
eaton_mini
Member #: 1649
Shame, I have a set of almost new (didnt even complete the run in stage) 18cc +0.20" in the shed..........
Monkeh
Member #: 1997
Lichfield
@stefaz - just called avonbar and told them that someone on here had only just ordered a set and received them almost straight away, and he told me they havent sent any out at all yet.. says they are still waiting on accralite, but should be out this week...
@eaton_mini - just curious, just in case, how much if you selling?
Want to sell? :)
eaton_mini
Member #: 1649
PM me your offers!!!
Post a price. This isn't eBay :)
eaton_mini
Member #: 1649
£380 plus postage
