| Home > Help Needed / General Tech Chat > quicky minisport 4 pots & 7.9 disks for 10" rims, any issies | |||||||
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
7th Jul, 2008 at 10:07:06pm
quicky minisport 4 pots & 7.9 disks for 10" rims, any issues, i'm considering cracking my credint card out 2moro
7th Jul, 2008 at 10:13:46pm
speak to anton first dude, i'm sure he was on about getting rid of his. On 20th Oct, 2015 Tom Fenton said:
8th Jul, 2008 at 01:56:38am
I'm having them since 7 years now,nothing to say, sure they haven't done a lot of milage, but I would go the same way again (I would certainly buy a set of 7.5 instead of 7.9 to have not clearance trouble and use the wheel I want ).
1050 Posts Member #: 764 Post Whore Staffordshire |
8th Jul, 2008 at 02:49:06am
possibly.. still considering the options :S |
8th Jul, 2008 at 07:48:19am
As Fab says reverse rims won't fit anything other than 7.5" discs and Cooper S calipers, not without spacers etc anyway. On 7th Nov, 2008 Nic said:
8th Jul, 2008 at 07:53:57am
I have some spacers lol. Im using 7.9s had no bother at all, they bled up very easy too.
8th Jul, 2008 at 06:03:05pm
what about 7.9's and slotmags? Drives
559 Posts Member #: 2775 Post Whore Aberdeen |
8th Jul, 2008 at 08:32:31pm
Slightly of topic. Mikerace what master cylinders is that you are using? And have you moved your pedalbox back inside the car? |
8th Jul, 2008 at 10:34:09pm
i have KAD 4 pots no issues with them fitting |
9th Jul, 2008 at 09:34:49am
Is it just the pic or is the track massively different front to rear Mike? |
9th Jul, 2008 at 09:46:59am
Nah not much difference mate, i did put silly spacers on the front as a temp measure. Lockfast, yes the cylinders have been moved back and are Ap Racing. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
9th Jul, 2008 at 05:11:00pm
yes slotmags are fitting above 7,9 |
9th Jul, 2008 at 05:27:44pm
i'bve been reding sometimes a spacer has to go between the drive flange & disk, to push the disk 2wards the car???? is this true, i dont reall want to use spacers, the only issue i have is if my starmags fit over ally calipers, i have s'disks but was thinking the alloy calper route to reduce wheight, + they're 4pots!!! even if i had to stick with 7.5 non vented it would be an improvement in braking & weight loss wou'nt it? SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
9th Jul, 2008 at 05:47:46pm
did have 7.5 std s ones (genuine on innocentis), they 're very good, used on track a few times ,with mintex 1144 pads nothing wrong to report .
