| Home > Help Needed / General Tech Chat > Bearing crush | |||||||
8th Jul, 2008 at 09:58:18am
Hi
8th Jul, 2008 at 11:00:52am
You should buy some plastigage.
8th Jul, 2008 at 11:20:18am
I've used plastiguage, everything was spot on.
8th Jul, 2008 at 02:03:24pm
Why would you use that crude cap bending method if you've used plastigage and found everything spot on?? On 13th Jul, 2012 Ben H said:
8th Jul, 2008 at 04:53:07pm
I was thinking in order to make sure the shell was sat tight in the rod, more then anything. On 7th Oct, 2010 5haneJ said:
8th Jul, 2008 at 06:44:37pm
V,
Edited by Rob H on 8th Jul, 2008. Isambard Kingdom Brunel said:
8th Jul, 2008 at 07:07:04pm
If course, you measure the roundness and size of rods and main journals BEFORE you fit the bearings. On 13th Jul, 2012 Ben H said:
