| Home > Help Needed / General Tech Chat > Sodding cam timing | |||||||
10th Jul, 2008 at 03:03:28pm
Hi
10th Jul, 2008 at 03:13:04pm
I dont like dowell adjustment, I prefer the vernier.
I seriously doubt it! |
10th Jul, 2008 at 03:15:01pm
I think so, but I'll try it again now.
559 Posts Member #: 2775 Post Whore Aberdeen |
10th Jul, 2008 at 03:36:44pm
Fit the pulley with a dowel in. Get the timming as close as you can as if setting with a fixed pulley and then remove the dowel and adjust from there. Had a similar problem a few years ago. |
10th Jul, 2008 at 04:10:14pm
as abouve you need to move the chain on the gear first then the dowel to alow 30' increments of adjustment.
On 17th Feb, 2009 Rob H said:
10th Jul, 2008 at 07:42:19pm
After 2 hours I'm still not close enough, I'm temped to stuff the fucking rubbish in a bin and buy verneers. If I'd known how much hassle it would have been I certainly would have in the first place.
![]() 399 Posts Member #: 793 Senior Member Milton Keynes |
10th Jul, 2008 at 07:51:29pm
I used to run one and they are an absolute pain in the arse to get spot on, but what you need is a 1 degree of set woodruff key an conjunction with the doweled duplex to allow you from 107 to 106 http://i28.photobucket.com/albums/c248/spe...er1/mini007.jpg
10th Jul, 2008 at 10:48:00pm
I find them OK. Line it up with a standard one, then you'll see where to begin. That works. On 13th Jul, 2012 Ben H said:
11th Jul, 2008 at 06:46:31am
thats why i just use a offset key plus they only cost a couple of quid. always looking for them bigger bunches of bannanas |
![]() 85 Posts Member #: 2234 Advanced Member Palm Beach Gardens, Florida |
11th Jul, 2008 at 08:22:28pm
Vegard and Paul have the clue. You started with the chain on the wrong tooth of the cam gear to get anything lined up. Pull the cam gear off. With the crank keyway at TDC the cam key should be at 1 o'clock. As you bring the cam gear up to fit it on the cam, you can see if any holes will be lining up, if not reposition the cam gear in the chain. |
12th Jul, 2008 at 01:50:14pm
Thanks, that position was after I had done much buggering about, That is just where it ended up for the photo. On 7th Oct, 2010 5haneJ said:
31st Jul, 2008 at 02:17:06pm
I was having a conversation with a mate last night on this very subject. He advised me that when fitting cams to his engine builds he would add an extra 2 degrees onto the the timming figure required run the engine in and then re-check the timing.
Own the day
31st Jul, 2008 at 05:10:50pm
I have tried with dowl type before and never done it, verniers are worth the £80 odd in my opinion!
31st Jul, 2008 at 10:01:23pm
I sorted it by the way, the issue was that you have to line the sprockets up with the dots facing each other (though there is no dot on the large sprocket) so I just placed the duplex on top of the single chain and lined the keyways up, that way I could get the slight adjustmet required.
