Home > General Chat > side entry distributor cap lead positions?
crumbs that was a long title
ok im using an aldon yellow with ignitory thing and a side entry cap from a maestro
which position is no.1? i cant quite remember but i think im using the one by where the ht lead goes in but the next clockwise position around, i.e. say the ht lead input was 12o'clock im using 1 o'clock for no1 cylinder
does it still use the 1-4-3-2 firing order?
did that make any sense at all? cheers
mark4765
Member #: 249
isnt it 1-3-4-2
sauber 200
Member #: 245
1-3-4-2 on mine,put my specs on now.lol
Edited by sauber 200 on 8th Aug, 2004.
giallofly
Member #: 164
The Stig..
Newport Pagnell
The Meastro cap is 1-3-4-2.(fact)
I always try to get 1 at 1/2 o'clock position.
ah might of said that wrong, ill give it another go next week, cheers
anyone wanna know what happens if you wire up the coil wrong-a big splattering of oil, thats what!!
my car and garage is covered
what maestro is the cap off? im going to get one this week sometime rather than the std metro one *smiley*
You can get side exit caps from Minispares, thats what i use.
Phil. *smiley*
Ive got a trade account at a lucas dealer *smiley* not paying the ?10 odd that minispares want...
Ill have to see if they've got one in stock so i can try it *smiley*
Need to make as much room as possible up front.
Usually, the '1' lead is the one closest to the vacuum advance unit.
It doesn't matter one bit however - you just put the leads on wherever they fit in the correct order, then move the dizzy drive to suit!
So can you get a side exit cap and arm that fits the mk2 electronic dizzy then?
The one i purchased from minispares ages ago was around 1/2" larger diameter than the previous dizzy cap... (i think the mk1 dizzy is a larger diameter cap then the mk2)
So what rotor arm is needed on these?
Iain - are you going to add a suitable arm/cap to the turbominis shop - or at least a part number???
Im using a Mk1 dizzy...
Yeah im looking at getting all the lucas bits added to the shop soon mate. Hopefully the shop will be expanding soon and im hoping to carry more stock. Still waiting to move house at the minute then want to get the books sorted and ill be away. may as well do the job properly! *smiley*
giallofly
Member #: 164
The Stig..
Newport Pagnell
The mk1 dizzy suits a meastro 1600 cap, they are not cheap, mine was ?16 ish some years ago.
You may may have to modify where the clips clip onto or use longer clip..it is easy stuff as i did it!
right so 1600 maestro it is. ill see what i can do, going to call in at dinner.
need to give the old girl a service although it is running very well considering its all 2nd hand plugs/leads etc that have been kicking about!
So unless you have the mk1 dizzy, you're screwed though....
possibly unless we can find another cap. Ill ask while im there. they are really good at finding info out for me and helping out.
Have to say id prefer a later dizzy as the install is neater than having that module seperate.
sauber 200
Member #: 245
my cap screws on,is this a later dizzy?
if so you can obviousley get the right cap,i can get a part number off it.
giallofly
Member #: 164
The Stig..
Newport Pagnell
sauber you must have the later dizzy with the module on the side.
The mk1 dizzy with the remote ignition pack has it's advantages as the pack does'nt get in the way if you don't run an oil cooler as it often fouls the oil link pipe.
TurboHarry
Member #: 115
Austria, near Vienna
GDC150 is the flat cap for the MK1 dizzy. Rotor GRA2130; also works with GRA2114 rotor. I am using this because I have the Metro turbo front rad. MK2 dizzy is a shade longer, so can't be used with a front rad on a round nosed Mini.
Bimmer Twinky headed and turboed A-Series:
http://www.minifreunde.at/harry/projects.htm
Cheers harry, ill get some prices tomorrow, didnt make it today, ran out of time chatting to Mike Barratt
i drilled 2 holes through the cap, and then some through the dizzy as there were some aluminium areas doing nothing, tapped it on and fixed with 2 screws a la metro style
well that was the plan, but i picked up the wrong drill bit and did the holes to big, but i got it sorted in the end
i think its from a maestro 1600, could be wrong though, and yep its damn expensive
killer_chiller
Member #: 325
how much sapce in front of the distributor does this dave over a standard one?
not much but a little bit
AV-R Technologies
Member #: 345
Guildford Surrey
The side cap in question is the old Maestro O series one you need to change the rotor arm as well. You will also need to gently cut off the original mounting lugs and file the top with a small slot that will engage the dizzy clips, we used all this type of system on my Miglia in 1996 with a front mounted rad.Saves 1.5" dependant on engine position.
http://www.avonbar.com
killer_chiller
Member #: 325
Anyone got some pics of a modified one? - With and with out the cap on?
good tip avonbar!
