Home > Help Needed / General Tech Chat > megajolt pressure take off options
lilrich
Member #: 3078
hiya peeps, im not sure where to put my pressure take off for my megajolt..... done a search and i have the impression most people take theirs off the inlet manifold.... can you also take it off the plenum chamber or would the manifold be better???
thanks for any help
Rich
turbO turBO tuRBO tURBO TURBO
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
The MAP sensor is used to measure load on the engine so you need it downstream of the butterfly. I imagine it would basically just measure boost if it was upstream of the butterfly
On 30th Apr, 2010 Rod S said:
Gary's description is best
lilrich
Member #: 3078
cool... thanks, ive been trying to imagine the two set ups in my head to try and figure out which would work best. I heard from somewhere taking it off the plenum would work but manifold i think it is..
thanks
philc
Member #: 1346
bromsgrove
here is a pic of mine though n/a it will give you an idea
SumpNut
Member #: 28
If you run the origional SU, could it just go to the nipple on the carb that the vacume advance origionally connects to?
The only thing to watch out for is that wherever you put the tapping receives both vacuum and pressure. There is a one way valve built into the standard metro turbo manifold above where the servo take off is, so this for example is not suitable.
Im using that without problems
